› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › DSL-AC68U New Firmware Version 3.0.0.4.386_39648 Yay new firmware – hopefully its a good stable build Version 3.0.0.4.386_396482020/09/0242.45 MBytes ASUS DSL-AC68U Firmware version 3.0.0.4.386_39648 (This product supports both Annex A and Annex B) Security Fix...
- This topic has 8 replies, 4 voices, and was last updated 6 years, 2 months ago by
September 2, 2020 at 10:27 pm #9469
Security Fix and Improvement:
– Fixed buffer overflow with shellcode of blocking_request.cgi..Bug Fixes and Improvements:
– Fixed and enhanced AiMesh related issues.
– Fixed the abnormal detect when WAN is set as static ip.
– Fixed web response slow issue in Web History page.
– Fixed link status error which cause sometimes cannot access internet in Load Balance mode.
– Fixed OUI may not be found in networkmap.
– Fixed Parental Control not work.
– Fixed udp proxy and igmpproxy issue in bridge mode.
– Enhanced nvram space usage.
– Fixed memory leak issue.
– Fixed deleting the events of AiProtection incorrectly.
– Fixed AiMesh RE sync wrong wep key.
– Fixed missing host keys to start ssh server.
– Fixed no client traffic data on APP.
– Fixed Load Balance Primary WAN disconnect cause Secondary WAN show disconnect too.
– Fixed crash issue if control Primary WAN in NetworkMap.
– Fixed DSL WAN MAC clone not work.
– Fixed DSL WAN PPP option not work.
– Fixed restart wan while editting multiple WAN PVC/Service list.
– Fixed Network Map internet status WAN control issue.
– Fixed WPS Button Behaivour is missing on GUI.
– Updated DSL ISP list and support more IPTV profile.You need to login in order to vote
September 3, 2020 at 4:40 am #9470Will be interesting if they fixed the reported bugs from this site.
1. the device scheduling is not working – if you set a device to block at a certain time it will stay blocked
2. RDP traffic seems to dropping every few minutes
and the SSH login error from there latest beta ?
September 4, 2020 at 8:45 am #9536ASUS have just contacted me and asked that I relay the following message regarding the new DSL-AC68U Firmware version 3.0.0.4.386_39648
Customers should all upgrade with this version, as there is one major Security Vulnerability fix
September 4, 2020 at 12:51 pm #9537Installed… I don’t see any issue, for now… I don’t even use any “advanced features”, but my aimesh network (1 master and 3 nodes, all dsl-ac68u) works flawlessly!…
September 4, 2020 at 12:57 pm #9538[quote quote=9537]Installed… I don’t see any issue, for now… I don’t even use any “advanced features”, but my aimesh network (1 master and 3 nodes, all dsl-ac68u) works flawlessly!…[/quote]
September 4, 2020 at 3:28 pm #9539[quote quote=9537]1 master and 3 nodes, all dsl-ac68u[/quote]Wifi or LAN backhaul to the nodes?
September 4, 2020 at 5:59 pm #9543[quote quote=9539]
Wifi or LAN backhaul to the nodes?[/quote]
All WiFi
September 4, 2020 at 8:10 pm #9548September 4, 2020 at 8:11 pm #9549[quote quote=9548]All seems good so far – ssh is working too[/quote]
They do listen sometimes
