DSL-AX82u login screen and Captcha DSL-AX82u login screen and captcha So I have been chatting with ASUS regarding Captcha and Screen Login and it seems for at least the DSL-AX82U and some other RT models…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › DSL-AX82u login screen and Captcha DSL-AX82u login screen and captcha So I have been chatting with ASUS regarding Captcha and Screen Login and it seems for at least the DSL-AX82U and some other RT models...
  • #9672
    • Replies 8,687
    So I have been chatting with ASUS regarding Captcha and Screen Login and it seems for at least the DSL-AX82U and some other RT models in use, ASUS does/ will use the following options for Captcha.
    • Captcha only shows  after two failed login attempts.
    • Captcha service has the option to be disabled (turned off)
    I did ask if ASUS could also add the option to only Enable Captcha  for WAN login authentication only , not both LAN and WAN and they are going to add this to there list for future consideration
