› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › GT-BE98 FW 3.0.0.6.102_34372/Adaptive QoS Broken Any value entered into in upload and download section don’t work. Some one can report? Thanks
- This topic has 5 replies, 2 voices, and was last updated 2 years, 4 months ago by
Roberto.
July 6, 2024 at 1:21 am #32729
July 6, 2024 at 7:11 am #32730. Roberto Said:Any value entered into in upload and download section don’t work.
If you can send a feedback form explaining the problem, from your routers UI and mention ‘UK Sentinel’ in comments box, this will hopefully help.
BTW: I am sure this is a known problem ASUS are already aware of with their Wifi 7 products and adaptive QoS not working (but I will remind them)
This reply was modified 2 years, 4 months ago by
UK Sentinel. Reason: added BTW comment
July 8, 2024 at 5:45 am #32738I Spoke with ASUS and they say the following for the GT-BE98
Don’t see the issue on GT-BE98 with 3.0.0.6.102_34372.
Suggest the user to try Private browsing/incognito mode or disable the extensions.
July 8, 2024 at 6:06 am #32739I’ll explain:
The values entered in the upload/download field are taken into account by the firmware but it is as if I entered 0/0.
In fact, if I exit and return the values are those entered by me.
It is precisely the QoS engine that does not take charge of the values even if they are apparently entered.
Maybe the tech department should test the QoS better than a hasty response.
Thank you.
P.S. however there is something contradictory between what the technical department says and what Merlin says. Merlin claims that all wifi7s have broken qos.
Roberto.
July 8, 2024 at 6:58 am #32741I don’t disagree, did you manage to send a feedback form ?
Did this issue also happen on previous firmware release ?
July 10, 2024 at 4:34 pm #32761 -
