Handy guide on how to check data usage on an iPhone or iPad Data Usage Check Guide for iPhone and iPad.   Step 1: On your iPhone or iPad, open the Settings app. Step 2: Tap the Cellular option. Note that it may be called Mobile Data or Cellular Data in some cases,…
› UKTH forums › Mobile › iPads › Handy guide on how to check data usage on an iPhone or iPad Data Usage Check Guide for iPhone and iPad.   Step 1: On your iPhone or iPad, open the Settings app. Step 2: Tap the Cellular option. Note that it may be called Mobile Data or Cellular Data in some cases,...
  • #32777
    Step 2: Tap the Cellular option. Note that it may be called Mobile Data or Cellular Data in some cases, depending on your device, iOS version, and regional settings.
    Step 3: Scroll down to the section labelled Cellular Data.
    Step 4: From here, you can see an overview of your data usage for the current period, including the total data used, data used while roaming (which usually costs more), and data used by each of your apps, sorted from the highest to the lowest. A toggle switch beside each app allows you to disable cellular data access for that app to help reduce your data usage.
    Ref:
    https://www.digitaltrends.com/mobile/how-to-check-data-usage-on-an-iphone/
