Hotpoint Tumble Dryer Fault Codes List of typical Hotpoint Tumble Dryer Fault codes; (as a guide)   Error CodeΒ  Β  Β  Β Fault Description F01 β€” Electronic circuit boardΒ fault. … F02 β€” Motor circuitΒ fault. … F03…
› UKTH forums › πŸ“Ί White & Brown Goods › Tumble Dryers › Hotpoint Tumble Dryer Fault Codes List of typical Hotpoint Tumble Dryer Fault codes; (as a guide)   Error CodeΒ  Β  Β  Β Fault Description F01 β€” Electronic circuit boardΒ fault. … F02 β€” Motor circuitΒ fault. … F03...
  • #11855
    F03 β€” Temperature sensing fault. …
    F05 β€” Waste pipe blockage or pump issue. …
    F06 β€” Door lock fault. …
    F07 β€” Electronic circuit board fault / heating circuit fault. …
    F08 β€” Heater fault.
    F09 β€” Software fault.
    F11 β€” Pump Circuit fault
    F12 β€” Electronic Control Units
    F13 β€” Dryer Temperature sensing fault (washer/dryer) only
    F16 β€” Drum lock sensor fault
    F18 – Internal Data Error
    Ref: https://www.hotpointservice.co.uk/tumble-dryer-repair/error-codes
