How to Run Two Monitors Off of One Computer? Running dual monitors is relatively easy and requires only a few connections and settings adjustments to complete. The dual monitor setup helps with your workflow by making an easy transition…
› UKTH forums › Computers › Monitors, Mouse & Keyboards › How to Run Two Monitors Off of One Computer? Running dual monitors is relatively easy and requires only a few connections and settings adjustments to complete. The dual monitor setup helps with your workflow by making an easy transition...
  • #12823
    Running dual monitors is relatively easy and requires only a few connections and settings adjustments to complete. The dual monitor setup helps with your workflow by making an easy transition between separate but related tasks
    Set Up Your Monitors
    Monitors are relatively inexpensive and even easy to find used, making a second monitor an easy decision for increased productivity. Modern monitors come with a variety of ports and will often have several cables included. Make sure you have the power cable and anΒ HDMI cableΒ for the connection.
    Not many monitors come with theΒ HDMI cableΒ included and you will likely have to purchase it separately. The cable is effective, however, and makes your setup run smoothly. The monitors may come with VGA or DVI cables but the HDMI is the standard connection for most office dual monitor setups. The VGA can work easily with a laptop to monitor connection, especially with a Mac.
    Before you go about setting everything up, position your monitors on your desk. Having two screens changes the perspective while requiring extra space. Slight tweaking to achieve a slight inward angle with your chair positioned somewhat centrally is comfortable. You also need to consider the extra cords, plugs and access required to reach outlets while positioning the monitors.
    Dual Monitor Cables
    With the monitors positioned, setup a power strip within easy reach. Plug the power cords into your power strip. Connect the first monitor to your computer through the HDMI port or through a VGA port, if desired.
    Do the same for the second monitor. If your computer only has one HDMI port and one VGA port, which is common, find an adapter to complete the connection. Adapters are often sold alongside the cables in retail stores. You don’t need to connect the monitors with the same cable styles to make it work.
    With the two monitor setup connected to your computer and a power source, turn the entire system on.
    Program the Monitors on Your Computer
    Programming the monitors to work as desired varies slightly by your operating system. Regardless, the overall process is relatively simple and straightforward.
    On a PC, right click on a blank space on the home screen and chooseΒ Display Settings. At this point, you must determine how the displays should work. You canΒ DuplicateΒ to have two separate displays doing the same thing. Or chooseΒ Extend DisplayΒ to work between two monitors. Extending is the common choice and you can drag windows between the two screens. Apply the desired settings and you are ready to use the dual monitor system.
    On a Mac computer, click theΒ MenuΒ thenΒ System Preferences. ChooseΒ Display SettingsΒ to reach the options. ChooseΒ MirrorΒ to display the same screen on both monitors or remove the check from theΒ MirrorΒ box to extend the display.
    Again, extend desktop is the preferred method for working withΒ dual screensΒ You can open and work on different applications in each monitor. The Mirror screen function does however work well when multiple monitors are used to share the same presentation. Adjust the angles and you can present to a large audience using this method.
    #12824
    A simple Dual Screen set up video
