Indesit Washing Machine Error Codes List of fault codes for indesit washing machines (as a guide)   Fault CodeĀ  Ā  Ā  Ā Description F01 —  Ā  Ā  Ā  Ā  Electronic circuit board fault. … F02 — …
› UKTH forums › White & Brown Goods › Washing Machines › Indesit Washing Machine Error Codes List of fault codes for indesit washing machines (as a guide)   Fault CodeĀ  Ā  Ā  Ā Description F01 —  Ā  Ā  Ā  Ā  Electronic circuit board fault. … F02 — ...
  • #11859
    • Replies 8,738
    F02 —  Ā  Ā  Ā  Ā  Motor circuit fault. …
    F03 —  Ā  Ā  Ā  Ā  Temperature sensing fault. …
    F05 —  Ā  Ā  Ā  Ā Waste pipe blockage or pump issue. …
    F06 —  Ā  Ā  Ā  Ā  Door lock fault. …
    F07 —  Ā  Ā  Ā  Ā  Electronic circuit board fault / heating circuit fault. …
    F08 —  Ā  Ā  Ā  Ā Heater fault. …
    F09 —  Ā  Ā  Ā  Ā Software fault.
    F11 —  Ā  Ā  Ā  Ā Pump Circuit failure
    F12 –Ā  Ā  Ā  Ā  Ā  Ā Electronic Control Fault
    F15 –Ā  Ā  Ā  Ā  Ā  heat control fault
    F16 –Ā  Ā  Ā  Ā  Ā  Drum lock position sensor fault
    F18 –Ā  Ā  Ā  Ā  Ā  Internal data error
