› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Latest Asuswrt-Merlin 386.13 available for ASUS AC models Asuswrt-Merlin 386.13 now available for all supported AC (Wifi 5) supported Routers Changes since 386.12_6: Release 7th-April-2024 NOTE: all the models supported by Asuswrt-Merlin on the 386_xx series are now...
- This topic has 1 reply, 1 voice, and was last updated 2 years, 7 months ago by
April 8, 2024 at 6:46 am #31855
NOTE: all the models supported by Asuswrt-Merlin on the 386_xx series are now officialy on Asus' End of Life list, which means unless there are new major security issues, no new updates will be provided by Asus. Asuswrt-Merlin will tentatively attempt to continue to provide updates and fixes until the end of 2024, at which point all the 386_xx models will no longer be actively maintained. - UPDATED: openvpn to 2.6.10. - UPDATED: miniupnpd to 2.3.6. - UPDATED: tor to 0.4.7.16. - UPDATED: OUI database used by networkmap and the webui. - CHANGED: QOS/Classification page can now resolve local IPv6 addresses. - CHANGED: Display tracked connections on the QoS/Classification page even if QoS isn't set to Adaptive QoS. - CHANGED: Prevent the use of Apple's iCloud Private Relay when enabling "Prevent client auto DoH". - CHANGED: NAT Passthrough page - removed the "Enabled + NAT Helper" option as the firewall no longer blocks traffic when set to disabled. This is back to the former behaviour, where this setting only controls whether or not to load the NAT helper. You might need to readjust that setting if you had previously changed it. - CHANGED: SIP, RTSP and H323 ALG (NAT helpers) are now disabled by default, as these legacy features tend to create issues with modern VoIP setups. This change will only apply to people doing a factory default reset of their router. - FIXED: CVE-2023-48795 in dropbear. - FIXED: Various issues with the QOS Classification page. - FIXED: UPNP leases without a description would not appear on the Forwarded Ports page. - FIXED: web server crashing when entering certain settings on the Network Filter Page. Bypassed bug in closed source validation code for now. - FIXED: Concurrent cronjob changes through cru could cause collisions, leading to missing jobs (dave14305) `https://www.asuswrt-merlin.net/download
April 8, 2024 at 6:55 am #31857ASUS Asuswrt-Merlin 386.13 was released yesterday and I have updated my RT-AC86U this morning (dirty flash).
Early days yet, flash went well and so far no obvious issues.
