› UKTH forums › π» Computers › Laptops › Lenovo Yoga 520-141kb uk Replacement 14" Screen Lenovo Yoga 520-141kb (uk) Replacement Screen I have an Lenovo Yoga 520-141kb (uk) laptop and alas the screen has cracked, it is a touch screen so I have disabled the...
- This topic has 16 replies, 3 voices, and was last updated 6 years, 3 months ago by
November 4, 2019 at 1:30 pm #4954
I have an Lenovo Yoga 520-141kb (uk) laptop and alas the screen has cracked, it is a touch screen so I have disabled the Touch Screen option under Device Manager > Human Interface Devices so it disabled the touch screen option.
This worked for a while but now screen flickers and distorts so I am looking to replace the screen.
Any body know of a good location to purchase replacement screens, preferable well priced as the laptop is one of my children’s.
November 5, 2019 at 1:26 pm #4958I have previously used ebay for buying damaged part of my MSI laptop which worked good …………… you can also try ebay or laptopscreen
-> https://www.laptopscreen.com/English/model/Lenovo/YOGA~520-14IKB/
-> https://www.ebay.com/itm/Lenovo-Yoga-520-14IKB-81C8-14-FHD-LCD-LED-Touch-Screen-Assembly-w-Digi-BD-Bezel/182934858725please consult seller to check if particular screen will fit your laptop
Edit:-
…. also make sure seller rating , reviews and selling policies are good and according to you if buying from ebayYou need to login in order to vote
November 5, 2019 at 1:38 pm #4961Thanks @XRW, so many unreliable traders/sellers out there, good to have another view/guidance
November 5, 2019 at 1:44 pm #4962yes many are ….. you can also take a look at Lenevo Service Center in UK nearby if you can find parts which would be cheaper and you will save custom cost
November 5, 2019 at 1:48 pm #4963[quote quote=4962]yes many are β¦.. you can also take a look at Lenevo Service Center in UK nearby if you can find parts which would be cheaper and you will save custom cost[/quote]
Good idea, I plan to remove screen from Laptop, check connectors are in good working order, then shop around, if laptop survives my screen removal attemptΒ
November 5, 2019 at 1:52 pm #4966That’s good plan
Install portable version of HWiNFO64 and find part number of screen .. which would be more easy for you to find parts ..because sometimes same screen is used in different models of laptop
Just look youtube for screen disassembly video .. so you know do and dont’s for your laptop
-> https://www.youtube.com/watch?v=izApxeUzNzM
-> https://www.youtube.com/watch?v=rz5s2pJ81J8
-> https://www.youtube.com/watch?v=UJlSlHUzESwYou need to login in order to vote
November 5, 2019 at 2:07 pm #4972@XRW – HWiNFO64 is a tool I have not used before, thanks for link and this may save me some time prior to screen removal
November 5, 2019 at 2:24 pm #4974you can also use any software that able to retrieve hardware informationΒ … some other i know is AIDA64 ……but i have found HWINFO portable easy to find stuffs , all you need to do is run ….
Example in attachment B173HAN04.0 is model number which is used in some ASUS and Dell 17″ Laptops
November 5, 2019 at 2:38 pm #4978Great, I will try HWINFO on my DELL laptop later,Β to test, but does look exactly as you suggest and will make my DIYΒ screen removal/replacement job easier on the Lenovo . thanks again ;-)
November 5, 2019 at 5:56 pm #4985usually there is a sticker on the backside of the screen where you find all infos needed.
November 6, 2019 at 1:28 pm #4991@XRW – I tried the HWINFO app on my Dell laptop and must say, great little tool and no cost.
Image of my Dell Laptop Screen details, now to install upon kids Lenovo
Many thanks to all
November 6, 2019 at 7:14 pm #4993November 6, 2019 at 7:42 pm #4994December 1, 2019 at 9:27 pm #5163Finally got around to replacing the screen on the 14″ Lenovo laptop, after a lot of shopping around, I ended up purchasing a brand new screen from AliExpress.com as I have an account. IΒ paid Β£70 which included delivery forΒ an LENOVO YOGA 520-14 Full HD (1920×1080) touch screen digitizer assembly which arrived about 10 working days after order was placed and was well packed etc.
Took me about 3 hours to remove old panel and remove electrics, wires, circuit boards. magnets and web cam etc.Β then re-add (with glue) to new screen digitizer assembly.
Kid is happy again and a few pounds (Β£) saved
Thanks to all whom gave me good advice
April 7, 2020 at 11:05 am #6333Ok, so I replaced my daughters LCD Touch Screen on her Lenovo yoga 520 14ikb a while ago and for a while everything was working well, then all of a sudden and for no real consistant reason, the screen defaults to vertical white/grey lines image and a power reset is required.
After a lot of online investigations, seems to be a common problem with the LCD Screen cable especially around the hinges CAUSING WEAKNESS IN THE WIRING ETC.
So ordered a new LCD Screen cable from Ebay for Β£6 (good price) and removed the original LCD Screen cable but unfortunately during the process accidently broke one of the screen sensors (lenovo ls-e543P) connector that plugs into the LCD Screen cable (they are very delicate)
Anyway β any ideas of where to get a new / usedΒ (lenovo ls-e543P) can be purchased as only a single seller on Ebay in UK selling one for Β£25 βouchβΒ β I have looked on Alibaba etc. and no luck as yet
Pics below (from internet) of lenovo ls-e543P screen sensor part and screen when image gets distorted
Note: I have tried the laptop without the sensor but seems to effect Touchpad and keyboard input, so an USB external mouse only solves half the problem and I do not want to disable the Touch screen option unless I have no other choice ;-)
New thread started for Screen Sensor – https://uktechhub.com/forums/topic/lenovo-yoga-520-14ikb-screen-sensor-replacement/
