› UKTH forums › 🛜 Wireless Routers & Modems › NetGear & Wireless › M4250 Firmware Version 13.0.4.19 M4250 Firmware Version 13.0.4.19 Last Updated:01/16/2024 Bug Fixes: Fixes the issue where memory usage increases slowly. Fixes the issue where the bit rate displays incorrectly under the Port Statistics...
- This topic has 0 replies, 1 voice, and was last updated 2 years, 8 months ago by
- January 20, 2024 at 8:12 pm #29306
Bug Fixes:
- Fixes the issue where memory usage increases slowly.
- Fixes the issue where the bit rate displays incorrectly under the Port Statistics in the AV UI.
- Fixes the issue where a problem occurs with the restoration of a backup configuration in the AV UI.
- Fixes the issue where an incorrect port configuration displays when you invoke the
‘swcfg_port’ Rest API.
Known Issues:
- In the Main UI, if you upgrade from firmware release 13.0.0.x to release 13.0.2.x, JavaScript errors might occur.
Workaround: After the firmware upgrade, clear your browser cache. - In the ProAV UI, restoring the configuration might fail.
Workaround: Restore the configuration through the Main UI.
https://kb.netgear.com/000065991/M4250L-Firmware-Version-13-0-4-19
