- This topic has 0 replies, 1 voice, and was last updated 6 years, 4 months ago by .
› UKTH forums › 📺 White & Brown Goods › Washing Machines › Miele Honeycomb Drum Design Miele Honeycomb drum The web-like surface structure of the Miele honeycomb drum creates a thin film of water between the drum and the laundry. This results in laundry gliding gently...
The web-like surface structure of the Miele honeycomb drum creates a thin film of water between the drum and the laundry. This results in laundry gliding gently and protects the fibres perfectly. The smaller, smoothly polished shouldered holes in the walls of the drum are also gentle on your textiles and prevent pilling and laddering. Foreign objects such as paper clips no longer end up in the drain pump.
I just wonder how good or relevant this is when compared to other washing machine manufactures drum design ?
