› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Moved: DSL-N16 Packet Loss Hi guys. I’ve been having packet loss issues on the upstream part of my FTTC (VDSL2) line, in the UK. I can test this by looking at the amount of...
- This topic has 119 replies, 3 voices, and was last updated 4 years, 8 months ago by
March 6, 2022 at 6:00 pm #18133
So, we brought a decent SD card earlier to flash OpenWRT to on the RP 4. Unfortunately, I couldn’t get it to boot when flashed to a USB 2 flash drive (I don’t think the support for USB booting is very good).
Then I installed a driver to get a USB to ethernet adapter to work.
I’ve setup the LAN and WAN connections, but so far no luck connecting to PPPoE with the DSL-N16 in bridge mode:
I will try using the TP-Link VR200 in bridge mode for the WAN later, which I know could connect to other routers.
Tbh, I’m unsure if I will definitely need two network interfaces for the OpenWRT setup.
March 6, 2022 at 6:37 pm #18139March 7, 2022 at 2:03 pm #18146Managed to get it working yesterday, with the TP-Link VR200 running as the VDSL modem.
devices are connecting with dhcp allocated IPs, and can access the Internet.
We’ve tried to change the fan profile on the Pi 4, as the default fan is pretty loud. But the editing the boot config didn’t seem to work for this.
So, we will probably just fit a lower RPM fan.
March 7, 2022 at 4:04 pm #18150Seems to be operating quite cool under load at around 33 Celsius. I’ve installed SQM which is working nicely too.
March 7, 2022 at 5:04 pm #18151March 10, 2022 at 1:17 am #18185I’ve been testing both the Technicolor DWA0120 and TP-Link Archer VR200.
It’s a bit early to say at the moment which is more stable as a modem. But the VR200 is getting no errored seconds so far on the upstream or downstream. But some CRC errors.
The DWA0120 is getting errored seconds on the upstream + upstream CRCs. Errored Seconds indicate a loss of signal apparently for 1 second.
So, the VR200 may be the best choice, particularly as the DLM bases line stats on the number of errored seconds (and resyncs as far as I know).
March 10, 2022 at 7:00 am #18187[quote quote=18185]. So, the VR200 may be the best choice, particularly as the DLM bases line stats on the number of errored seconds (and resyncs as far as I know).[/quote]
The VR200 has a Lantiq DSL chipset, so that makes sense why it is performing slightly better
March 10, 2022 at 11:44 am #18189Unfortunately, the OpenWRT device isn’t idiot proof. My dad disconnected the WAN (and LAN connection) which was connected via the USB adapter. Somehow, the drivers got scrambled and uninstalled. And the PPPOE option disappeared completely from the user interface.
So… I reflashed the image to the SD card. That didn’t work. Then I restored the device’s factory defaults, which restored the PPPOE connection option. Then I restored my settings from a backup.
Then, I had to connect another router with an internet connection to the OpenWRT router, so that it had an internet connection (which it needs to download drivers / required files). Then, I was able to reinstall the USB drivers and restore the WAN connection. Phew.
He was only trying to help though, as he was just installing a new case which runs silently (The loud case fan was bothering my brother :D, who said he was going to remove it). Could do without the drama…
March 10, 2022 at 12:11 pm #18195So, these are the stats I recovered from the Archer VR200 using a tool called Stat Grabber:
Lots of CRCs, which always seems to occur on sync up. 24 million FECs so far. These numbers don’t seem to be increasing after sync though.
March 10, 2022 at 12:21 pm #18196Family, always fun and compromises
I wonder if the Stat Grabber is remembering the total number of FEC/CRC, it has ever had ?
Best as you are doing just to monitor and see if they (CRC/FEC) increase over time ?
March 10, 2022 at 12:34 pm #18197The TP-Link VR200 modem web interface reports packet errors on the downstream (16 so far). I think these are probably just downstream CRC errors (after line sync).
I will probably do an SD card backup of OpenWRT later, to save myself a nightmare reinstall if anything ever goes wrong again
March 12, 2022 at 10:55 pm #18239Still not getting any errored seconds on the TP-Link Archer VR200 (After a few days), which is good.
I’m starting to wonder if it even reports these errors correctly though. Would’ve thought 1-2 errored seconds per day would be typical on most lines.
I remember that this router used to sync at 57mbps downstream (same line) back in 2017, but now it’s around 45mbps. Do you reckon that could be caused by crosstalk?
Still, it seems to be working well so far, and the WiFi actually works properly in bridge mode.
March 13, 2022 at 8:17 am #18248[quote quote=18239]I remember that this router used to sync at 57mbps downstream (same line) back in 2017, but now it’s around 45mbps. Do you reckon that could be caused by crosstalk?[/quote]
Maybe a busier cab, hence lower synch rate or throughput over time.
Screen dumps DSL line stats if you can ?
March 13, 2022 at 7:40 pm #18252It’s OK, it synced higher today at just under 50mbps. So, it looks like it’s the best one for my line – Presumably it synced higher due to not having Errored Seconds as of yet.
March 13, 2022 at 9:31 pm #18261 -
