Need help resetting win10 password My computer was hacked by someone and not able to login in the device with my initial password. I suspected the hacker changed my password so I need to get…
› UKTH forums › 💻 Computers › Windows (OS) › Need help resetting win10 password My computer was hacked by someone and not able to login in the device with my initial password. I suspected the hacker changed my password so I need to get...
Viewing 12 posts - 1 through 12 (of 12 total)
  • #6039
    Avataryyzcaew
    • Replies 2
    My computer was hacked by someone and not able to login in the device with my initial password. I suspected the hacker changed my password so I need to get it back. How can I reset forgotten password on Windows 10?
    #6040
    • Replies 1,039
    Second paragraph ‘Create a New User to Save Account Files’:
    https://www.howtogeek.com/222262/how-to-reset-your-forgotten-password-in-windows-10/
    https://www.top-password.com/knowledge/reset-windows-10-password.html
    #6042
    • Replies 8,718
    Hopefully you set a security question/pin when you created the account originally, if you did then just
    To Reset your Windows 10 local account password:
    • Select the Reset password link on the sign-in screen. If you use a PIN instead, see PIN sign-in issues.
    • Answer your security questions.
    • Enter a new password.
    • Sign in as usual with the new password.
    #6043
    Avataryyzcaew
    • Replies 2
    [quote quote=6042]Hopefully you set a security question/pin when you created the account originally, if you did then just To Reset your Windows 10 local account password:
    [/quote]
    it is a local account password, so the above method does not work in my case
    #6044
    • Replies 8,718
    I see, hopefully @Grisu advice has helped
    #6045
    • Replies 1,039
    worked always for me in the past, W7/8/10
    activate admin account with description from the links, and you’re done.
    #6047
    • Replies 8,718
    [quote quote=6045]worked always for me in the past, W7/8/10 activate admin account with description from the links, and you’re done.[/quote]
    #6049
    Avatarshire34
    • Replies 2
    As i did before,the Windows password can be reset by Windows password reset disk,do you have a password reset disk? It can solve your problem quickly,you just need to plug it into your computer,after the computer reboot,it will reset Windows 10 password for you.
    #6066
    Avatarshire34
    • Replies 2
    [quote quote=6040]Second paragraph ‘Create a New User to Save Account Files’: https://www.howtogeek.com/222262/how-to-reset-your-forgotten-password-in-windows-10/
    https://www.androidphonesoft.com/resources/reset-windows-10-password.html[/quote]
    A good idea for resetting Windows 10 password,don’t reinstall Windows 10,that is a disaster.
    #6072
    • Replies 1,039
    I know
    #10699
    AvatarDaniel
    • Replies 5
    • Replies 1,039
    This MS-manual will only work with online accounts!
    Thats easy and not the question, we want access to local accounts.
