Netgear D7000-100UKS Hardware Specs Netgear D7000-100UKS (hardware) PU1: Broadcom BCM63138 (1 GHz, 2 cores) FLA1: 128 MiB RAM1: 256 MiB Expansion IFs: USB 3.0 USB ports: 2 WI1 chip1: Broadcom BCM43602 WI1 802dot11 protocols:…
› UKTH forums › Wireless Routers & Modems › NetGear & Wireless › Netgear D7000-100UKS Hardware Specs Netgear D7000-100UKS (hardware) PU1: Broadcom BCM63138 (1 GHz, 2 cores) FLA1: 128 MiB RAM1: 256 MiB Expansion IFs: USB 3.0 USB ports: 2 WI1 chip1: Broadcom BCM43602 WI1 802dot11 protocols:...
  • #401
    FLA1: 128 MiB
    RAM1: 256 MiB
    USB ports: 2
    WI1 802dot11 protocols: bgn
    WI1 MIMO config: 3×3:3
    WI1 antenna connector: none
    WI2 chip1: Broadcom BCM43602
    WI2 802dot11 protocols: an+ac
    WI2 MIMO config: 3×3:3
    WI2 antenna connector: none
    ETH chip1: Broadcom BCM63138
    Switch: Broadcom BCM63138
    LAN speed: 10/100/1000
    LAN ports: 4
    WAN speed: 10/100/1000
    WAN ports: 1
    UK Sentinel
