New RT-AX68U Firmware version 3.0.0.4.388_24646 ASUS RT-AX68U Firmware version 3.0.0.4.388_24646 Version 3.0.0.4.388_24646 Release date: 2024/02/26   Bug Fixes and Enhancements: – Enabled DynDNS and No-IP DDNS to use IPv6. – Enabled WireGuard Server clients to…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › New RT-AX68U Firmware version 3.0.0.4.388_24646 ASUS RT-AX68U Firmware version 3.0.0.4.388_24646 Version 3.0.0.4.388_24646 Release date: 2024/02/26   Bug Fixes and Enhancements: – Enabled DynDNS and No-IP DDNS to use IPv6. – Enabled WireGuard Server clients to...
  • #31043
    • Replies 8,699
    – Enabled WireGuard Server clients to access the Samba server.
    – Enabled the failback function when using the iOS/Android USB backup WAN.
    – Improved AiMesh backhaul stability.
    – Improved Wireguard performance.
    – Improved consistent display of client status on the WireGuard server.
    – Improved system stability when accessing the WireGuard Server with DMZ enabled.
    – Improved memory utilization and fixed an occasional server error when registering DDNS with an app.
    – Modified the USB application option text in dual WAN.
    – Fixed network map bugs.
    – Fixed memory leak issue.
    – Fixed v6plus related Issues.
    – Fixed ipv6 network service filter not work.
    – Fixed the IPsec VPN compatibility issue with Win10.
    – Fixed the reboot issue when assigning specific clients in VPN fusion.
    – Fixed Client DOM Stored XSS vulnerability.
    – Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
    – Fixed the problem that the AiCloud app cannot add router on Android 9.
    – Fixed the issue where Traffic Analyzer sometimes couldn’t record data.
    – Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
    – Fixed AiMesh preferred AP identification in site survey results.
    – Fixed a bug encountered when adding a rule to the network services filter.
    – Fine-tuned the description for port status.
    – Resolved the issue with login and password changes.
    – Resolved the IPSec VPN connection issues.
    – Resolved OpenVPN Server TAP Mode Issue.
    – Resolved the Instant Guard connection issues.
    – Resolved the ARP response issue, along with the connection issue between the router and the ROG Phone 6 and 7.
    – Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node.
    Security updates:
    – Enabled and supported ECDSA certificates for Let’s Encrypt.
    – Enhanced protection for credentials.
    – Enhanced protection for OTA firmware updates.
    – Enhanced protection against SSH brute force attacks.
    – Fixed CVE-2022-46871.
    – Fixed Client DOM Stored XSS.
    – Fixed DoS vulnerabilities in httpd and firewall configuration pages.
    – Fixed information disclosure vulnerability.
    – Fixed null pointer dereference vulnerabilities.
    – Fixed the cfg server vulnerability.
    – Fixed FFmpeg vulnerabilities.
    – Fixed several curl vulnerabilities.
    – Fixed CVE-2023-28702 and CVE-2023-28703.
    – Fixed an OpenVPN vulnerability categorized as CWE-134.
    – Fixed the vulnerability in the logmessage function CVE-2023-35086/ CVE-2023-35087.
    – Fixed security issues on the status page.
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax68u/helpdesk_bios?model2Name=RT-AX68U
    #31088
    • Replies 8,699
    I am reading on other Forums that Guest wifi internet access cannot be blocked with the previous release, unsure if this has been fixed for this RT-AX68U Firmware version 3.0.0.4.388_24646 ?
    #31612
    • Replies 8,699
    I have just seen that the RT-AX68U has reached its EoL, but strange ASUS released firmware last month ?
    https://www.asus.com/event/network/EOL-product/
    Will have to see if ASUS release any new firmware or whether ASUS RT-AX68U Firmware version 3.0.0.4.388_24646 will the last release, ever ?
    #31930
    • Replies 8,699
    Another EoL firmware release by ASUS for the RT-AC68U
    ASUS RT-AC68U Firmware version 3.0.0.4.386_51685
    Version 3.0.0.4.386_51685
    2024/04/15
    Changes:
    – Fixed command injection vulnerability.
    – Fixed the ARP poisoning vulnerability. Thanks to the contribution of Xin’an Zhou.
    – Fixed code execution in custom OVPN. Thanks to the contrubution of Jacob Baines.
    – Fixed the injection vulnerability in AiCloud.
    – Fixed stack buffer overflow in lighttpd. Special thanks to Viktor Edstrom.
    – Fixed CVE-2023-35720
    – Fixed the code execution vulnerability in AiCloud. Thanks to the contribution of chumen77.
    – Fixed the XSS and Self-reflected HTML injection vulnerability. Thanks to the contrubution of Redfox Cyber Security.
    *Please be advised that due to a security upgrade in AiMesh, we strongly recommend against downgrading to previous firmware versions, as this may lead to connection issues. Should you encounter any difficulties, resetting the AiMesh router to its default settings and re-establishing the mesh connection can resolve the problem.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-wifi-routers/rtac68u/helpdesk_bios?model2Name=RTAC68U
