› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Remote play Series X & PS5 don’t work with AiMesh….outdoor This is my configurazione: DSL AC68U as node. DSL AX82U as master Firmwares updated. If i force connection with master all ok. If i force connection with node don’t work....
- This topic has 6 replies, 2 voices, and was last updated 3 years, 2 months ago by
September 10, 2023 at 8:57 am #26829
DSL AC68U as node.
DSL AX82U as master
Firmwares updated.If i force connection with master all ok.
Any advise?
Thanks.(Sorry for my bad English)
P.S. Factory reset don’t help
September 10, 2023 at 9:06 am #26830With the PS5, is it NAT Type 1 you are having an issue achieving ?
Is AiMesh configured as wireless or wired for DSL-AC68U as DSL-AC68U only supports being AiMesh node via wireless?
September 10, 2023 at 2:35 pm #26833With the PS5, is it NAT Type 1 you are having an issue achieving ?
First, thanks for your help and time.
The issue is not NAT Type
(My actual nat type for ps5 is “2” and for Xbox is “open”………”2” and “open” is the same Word)
With dsl ac68u only aimesh possibile is wireless, because the modem don’t have a wan port.
Only mode for achieving NAT type 1 is it use PPPoE relay, but………….with aimesh node don’t work!!!
PPPoE relay work fine with master connection.
Issue is in the Last firmware of modem dsl ax82u, because before is all fine.
September 10, 2023 at 3:00 pm #26834Have you tried reverting back to the previous firmware for the DSL-AX82U to see if the problem is resolved, if not take a backup of config and see if that helps ?
I assume, that as DSL-AX82U is 388 build and DSL-AC68U is 386 firmware build, compatibility via AiMesh will get worse over time between these two build versions.
I will check with ASUS to see when the next firmware for the DSL-AC68U might be available, as this might help also ?
September 10, 2023 at 4:08 pm #26835You won’t believe it, but I found the solution!!!!
The problem is the Xbox!!! which causes the PS5 to have a network problem as well.
Game priority must be deactivated in the Xbox options (Advanced option, TAG QoS)
I don’t understand how, but this option doesn’t even allow the PS5 to work properly.
As an ignorant person, I believe that this option creates a malfunction in the network and does not allow dialogue.
Some professionals should analyze this problem.
Now PS5 and XBOX work perfectly.
Thank youYou need to login in order to vote
September 10, 2023 at 5:24 pm #26836September 11, 2023 at 7:31 am #26841ASUS have come back and are planning to release the next firmware update for the DSL-AC68U at the end of QTR 4 – this year
