Renault Kadjar Service Reset Message / Light So the Renault Kadjar Service light (warning light) has appeared as I forgot to reset the Service history after I serviced the car at the end of last year. (Note:…
› UKTH forums › Life & Stuff › Cars › Renault Kadjar Service Reset Message / Light So the Renault Kadjar Service light (warning light) has appeared as I forgot to reset the Service history after I serviced the car at the end of last year. (Note:...
  • #18169
    • Replies 8,738
    (Note: service/warning light (spanner) and service message can appear due to either Oil change being required and/or mileage or time from last service being exceeded.)
    I thought I would share how to reset the Renault Kadjar service warning light for both my future reference and for others if they every need to.
    Quick Guide:
    • Using the steering wheel select paddle (next to OK button) scroll until you find the ‘Service Intervals’ option
    • Press and hold the Steering wheel OK button for 5 (ish) seconds – until the Service Intervals message flashes and then stops
    • Then using the Steering wheel select paddle scroll up or down until you see ‘Oil Change’ message appear, then press the OK button and keep pressed until ‘Oil Change’ message stops flashing.
    • Then using the Steering wheel select paddle scroll up or down until you see ‘Service In’ message appear, then press the OK button and keep pressed until ‘Service In’ message stops flashing, at then this should also turn off the Service Required symbol.
    • If you then turn off ignition (press stop/start button) and then turn back on power you should notice that the Service Required symbol and warning message are no longer displaying
    Detailed Guide:
    Push the stop/start button but do not start the Kadjar
    #18171
    • Replies 8,738
    Handy video via Youtube to help explain the Renault Kadjar Service reset procedure.
