› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ROG Rapture GT-BE19000 tri-band WiFi 7 gaming router ASUS announced the other day the new ROG Rapture GT-BE19000 tri-band WiFi 7 gaming router New router features Smart AiMesh with Multi-Link Operation, exclusive Gaming Network, Automatic Frequency Coordination...
- This topic has 5 replies, 2 voices, and was last updated 1 year, 2 months ago by
June 4, 2024 at 4:38 pm #32427
- Delivers tri-band WiFi 7 speeds of up to 19 Gbps and wired capacity of up to 31 Gbps, including dual 10 Gbps and four 2.5 Gbps Ethernet ports
- For the best experience, Gaming Network combines all gaming features into a single SSID, so gamers don’t need to configure each device individually
- Smart AiMesh leverages WiFi 7 Multi-Link Operation, enabling automatic WiFi band selection for stable mesh networks and smoother streaming and gaming
- Cutting-edge features such as Smart AiMesh and Guest Network Pro (or Smart Home Master) now available on many ASUS and ROG WiFi 7 routers
June 4, 2024 at 6:32 pm #32431June 4, 2024 at 6:43 pm #32432If only, will be interesting to see what price the new ROG Rapture GT-BE19000 is when its released in the UK as 2025 is when full fibre hits our area
April 19, 2025 at 11:53 am #37226ASUS GT-BE19000 Firmware version 3.0.0.6.102_37447
Version 3.0.0.6.102_3744769.07 MB 2025/04/14SHA-256 :AF1B10420962C0BB528E7051453EDAD33027FA843B0F36A31CFBFDB4825452711. Fixed the UI issue in Chrome.
4. Enhance system access control mechanisms.https://rog.asus.com/uk/networking/rog-rapture-gt-be19000/helpdesk_bios/
April 25, 2025 at 9:19 am #37318ASUS GT-BE19000 Firmware version 3.0.0.6.102_37838version 3.0.0.6.102_378382025/04/231. Implemented a security patch to address an OpenVPN issue.
2. Fixed display issues that could occur during the login process.
3. Fixed a potential DNS Open Resolver vulnerability.
4. Fixed a problem affecting 5 GHz connections when operating in repeater mode.
5. Fixed an anomaly in the wireless scheduler functionality.
6. Fixed an issue preventing the configuration of time scheduling for the SDN client.
7. Fixed an issue causing Movistar IPTV to malfunction due to incorrect firewall rules.
8. Improve 5G Wi-Fi connection stability
9. Improved compatibility with IoT devices when using WPA2+WPA3 security protocols.
10. Improved the stability of remote connections via the app.
11. Enhanced the stability of MLO (Multi-Link Operation) connections.https://rog.asus.com/uk/networking/rog-rapture-gt-be19000/helpdesk_bios/
August 10, 2025 at 5:43 pm #39030ASUS GT-BE19000 Firmware version 3.0.0.6.102_37899
2025/08/08
Security Enhancements:
– Detailed Audit Trails – Expanded logging within the authentication module.System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.https://rog.asus.com/uk/networking/rog-rapture-gt-be19000/helpdesk_bios/
