RT-AX86U wired network connection to second WIFI network Hi all, So I have setup a 2nd WIFI network which I’ve connected all my IOT devices to. I’m now considering setting up home assistant on a virtual machine and…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › RT-AX86U wired network connection to second WIFI network Hi all, So I have setup a 2nd WIFI network which I’ve connected all my IOT devices to. I’m now considering setting up home assistant on a virtual machine and...
Viewing 3 posts - 31 through 33 (of 33 total)
  • #24375
    • Replies 1,243
    Thanks, yes that looks to be how to enable VLANs.  I see so I’d have to effectively remove WIFI 2 from the main router and use a separate device for WIFI 2 and then assign port switch to different VLAN ID and then also assign a separate VLAN ID.  Only catch now is getting my VM to have a second NIC on that same VLAN when physically its wired to main network….
    Thanks for info! Will look at the AX repeater too thanks.
    • Replies 8,707
    That would be the simplest way using your current RT-AX86U as Router 1 and ensuring everything runs via the switch for separation etc.
    #24392
    • Replies 1,243
    Thanks, will have to look into this…
    Currently having fun and games with good old BT…… (new thread inbound on that over in that section)
