Samsung Washing Machine Error Codes Samsung Washing Machine Fault Codes and What they Mean ? (as a guide)   E4 – Water supplyΒ error. The appliance is not detecting that the unit is filling with water….
› UKTH forums › πŸ“Ί White & Brown Goods › Washing Machines › Samsung Washing Machine Error Codes Samsung Washing Machine Fault Codes and What they Mean ? (as a guide)   E4 – Water supplyΒ error. The appliance is not detecting that the unit is filling with water....
  • #11848
    3E – Motor defect
    3E1
    3E2
    3E3
    3E4
    4E1Β  – Water temperature issue.
    4E2
    5C – Water drainage issue. Water is not draining from appliance
    5E
    5D – Standby mode due to error
    6E – Water heater not functioning
    8E – Over current error
    9E1 – Power error
    AE – Signal communication error between Main PCB and Sub PCB
    bE – Motor issue
    bE1 – Power button issue
    https://www.samsung.com/levant/support/home-appliances/washing-machine-what-does-the-error-code-means-and-how-to-fix-it/
    #11849
    More Samsung Washing Machine error Codes
    B2 – Control button issue
    bE2
    bE3 – Button defective
    CE – Water cool down issue
    dE – Door issue
    dE1
    dE2 – On/Off switch error
    FE – Fan error
    H1 – Water temperature issue
    HE
    HE1 – Water heater not functioning
    HE2 – Dryer heater not functioning
    HE3 – Steam function does not operate normally
    HOT – Appliance too hot
    LE – Natural drain/Water leak – Low water level detected during cycle.
    LE1
    OE – Overflow error
    OF
    t1 – Appliance in test mode
    ee2/t2
    tSt
    SUD (sometimes misread as 5UD) – This occurs when too much foam is detected and is displayed whilst foaming is being removed.
    tE – Temperature sensor issue
    tE1 – Temperature sensor error
    tE2
    tE3
    UC – Excessive fluctuation in the supply voltage
    UE – Unbalanced error – The load in the drum is unbalanced.
    #11854
    Samsung Washing Machine WW9 / WW8 & WW7 Fault Codes
    4C – Water is not supplied
    4C2 – Cold Water Supply problem
    5C – Water is not Draining
    dC – Door Open
    OC – Water has overflowed
    LC – Check Drain hose
    LC1
    Ub – Spinning does not work
    3C – Check the motor for operation
    UC – Electronic Control or Low voltage detected
    HC – High Temperature Heating Check
    1C – Water level sensor faulty
    AC – Check connection between main and sub PBA’s
    8C – Mems sensor not working
    AC6 – Check comminications between main and inverter PBA’s
