› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Sky and ASUS Routers – setup simplification help Hi all, I have a really odd set up that I’d like help simplifying. I recently moved house, having 2 houses for a duration I have my old set up...
- This topic has 4 replies, 2 voices, and was last updated 6 years, 4 months ago by
- May 27, 2020 at 4:56 pm #7698
I recently moved house, having 2 houses for a duration I have my old set up using a ASUS RT-AC3200. I’ve got all manner of fixed IP’s on it to about 15 devices, Linux, Citrix the lot and don’t really want to have to reconfigure them. I have multiple LANs configure using the visitors functionality but that’s easy to sort out.
The new house has an RT-AX88U with no real exciting set up Other than it has to act as an “Access Point” mode to a Sky Broadband router since sky make it painful to remove it from the chain apparently.
So I’ve moved into the new house bringing my RT-AC3200 with. I LOVE the QoS and traffic throttling capabilities so want that as the router that everything connects to (including the kids Wi-fi devices). This is where it gets interesting.
If I plug the RT-AC3200 into a netgear switch on the new network with the WAN being Ethernet, all works well, it just annoyingly is on a different subnet and I’ll have to re-route a load of cabling. If I plug in the RT-AC3200 into the RT-AX88U directly it keeps dropping the WAN saying the DHCP Server does not function correctly :( I could move all of this into one big cupboard and have a ridiculously complicated set up, or…..
1. Buy ANOTHER router ADSL for Sky and work out how to replace the sky freebie (any recommendations ? I like the bandwidth monitoring and throttling of ASUS). And the ASUS ones too. Oh and that means remapping all of the static IPs on 15 devices
2. Replace the RT-AX88U with the RT-AC3200 Change it to an access point and lose all the QoS I like :( Keeping the static IP’s though.
3. AOIdeas ?My broadband is 6Mbps down, 0.5Mbps up, hence why I need to monitor what’s going on, as I work from home a lot too. In addition I also have to use 4G for video conferencing.
Thanks in advance
Ian
May 27, 2020 at 5:56 pm #7703Hi Ian, nice little conundrum, firstly can I ask why connection is so low, are you located where there is no other / faster options ?
May 27, 2020 at 6:16 pm #7705Near Colchester, this is the fastest option I can currently get, old copper wires with FTC, one day they will fibre it up to the house but I might not live that long.
May 27, 2020 at 6:58 pm #7707Near Colchester, this is the fastest option I can currently get, old copper wires with FTC, one day they will fibre it up to the house but I might not live that long.
Bad luck, so you are on ADSL, just need to know the basics before going forward as a new modem may be a good way forward for your sky connection
May 27, 2020 at 8:17 pm #7712your RT-AC3200 is a dual core 1 GHz processor, the RT-AX88U is a quad core 1.8 GHz processor with wifi 6 standard, so a little more future proof.
Also, try this link to so what synch speeds are available in your area –
https://www.broadbandchecker.btwholesale.com/#/ADSL
https://www.sky.com/shop/choose/add-broadband/product-selection?irct=BBSpeeds-Hero-swcb
My thoughts:
As you connection has a low synch rate/speed, I would opt for a Broadcom modem as they synch higher than other modem chipsets, something like a BT HG612 from Ebay for around £20 if you are using ADSL etc…..
If there is a faster isp service/package available, the the DrayTeK 130 modem and is a good choice at higher speeds and it shows line stats etc,, (alas not Broadcom DSL chipset)
Then use the ASUS RT-AX88U set up to run on Sky credentials (easily done) and then have the RT-AC3200 as a access point or use AiMesh etc. (should work OK)
Some re-configuration required, but a good use of the kit you have and removes the Sky router which is far from ideal
is the QoS for the RT-AC3200 and AX88U that different, if they are I assume this is just because the firmware for the AX88U is less mature ?
There is also another firmware suitable for ASUS routers called ASUSWRT-Merlin, and is worth a look – https://www.asuswrt-merlin.net/ as this will enable the use of SKY MER DHCP option 61 (MER) if you are using PPPoE etc.
A lot to consider
