- This topic has 0 replies, 1 voice, and was last updated 5 years, 1 month ago by .
› UKTH forums › 🛜 Wireless Routers & Modems › NetGear & Wireless › Access DrayTeK Vigor 130 Stats from behind a Netgear Router I posted this over at Netduma, so thought I should include in my forum also, before I forget So if you have a Netgear Router (including XR Series) and a...
I posted this over at Netduma, so thought I should include in my forum also, before I forget ![]()
So if you have a Netgear Router (including XR Series) and a DrayTeK Vigor 130 modem, then it is not possible (or I have not found a way) to gain access to the Drayteks stats (UI) via the Netgear router unless you unplug the Ethernet cable between router and modem which is not ideal.
I have tried adding static routes, enabling Telnet access on my XR500 and entering ip route add 192.168.1.0 255.255.255.0 192.168.2.100 static etc etc etc..
What worked for myself was to use a small 4 to 8 port switch between the DrayTek 130 and XR500.
Connect my Laptops Ethernet cable into that switch with an IP of 192.168.2.2 (manual IP address on that interface) – (no gateway needed)
Then at your browser type 192.168.2.1 to enable you to login and get your stats etc.
Note: my TP-Link 5 port switch likes it when the Ethernet cable from the laptop plugs into Port 1 ? – Ports 4 and 5 are used for the connection from DrayTek 130 to my XR500
(switch only adds marginal delay – so not big issue when gaming)
Still works as of today (24/09/2021) but far from an ideal workaround.
Note: ASUS RT Routers do not have this problem, only Netgear kit.
