› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX68U Firmware version 3.0.0.4.388_24761 New ASUS RT-AX68U Firmware version 3.0.0.4.388_24761 version 3.0.0.4.388_24761 2025/08/22 Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment. Security Enhancements:...
- This topic has 2 replies, 2 voices, and was last updated 1 year, 3 months ago by
August 25, 2025 at 5:42 am #39326
2025/08/22
– Detailed Audit Trails – Expanded logging within the authentication module.System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client listYou need to login in order to vote
August 25, 2025 at 9:52 am #39335Thanks for this, not updated mine for a while as was waiting to ensure all is ok. Incidentally, if current password doesn’t meant the password policy update, will it prompt to change it or will it just not allow you to login therefore should I update it before doing the update to a password that meets requirements?
Looking on another forum, not seen any comment on the firmware yet i.e. working, not working, issues, no issues so will give it a while before I update.
August 25, 2025 at 4:39 pm #39336I believe that if you current ADMIN password is not changed and does not meet ASUS the new Password Policy requirements and you also perform a dirt flash, then the existing password will still allow you to log into router UI.
A factory reset will enforce the new ASUS password policy.
Note: Considering the inherent exposure of routers to the internet, enforcing strong default passwords is both a fundamental security requirement and an established best practice nowadays.
