ASUS RT-BE92U – Official Thread
UKTH forums ๐Ÿ›œ Wireless Routers & Modems ASUS & Wireless ASUS RT-BE92U – Official Thread
Viewing 14 posts - 1 through 14 (of 14 total)
  • #34747
    • Replies 8,457
    New RT-BE92U Firmware 3.0.0.6_102_37025
    11/05/2024
    – Release note –
    Bug Fixes and Enhancements๏ผš
    1. Optimized memory management mechanisms, improving system efficiency and stability.
    5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
    6. Resolved SDN-MLO invalidation after system reboot.
    https://www.asus.com/uk/networking-iot-servers/wifi-7/all-series/asus-rt-be92u/helpdesk_bios?model2Name=ASUS-RT-BE92U
    #35185
    • Replies 8,457
    New ASUS RT-BE92U Firmware version 3.0.0.6.102_37435
    Version 3.0.0.6.102_37435
    12/23/2024
    Bug Fixes and Enhancements:
    – Resolved enabling Instant Guard could cause unexpected restarts.
    – Fixed a potential restart issue when using the Feedback system.
    – Fixed MAC Filters limit being restricted to 16, increased to 64.
    – Improved device connection stability on MLO Network.
    – Enhanced MLO backhaul stability.
    https://www.asus.com/uk/supportonly/rt-be92u/helpdesk_bios/
    #35634
    • Replies 8,457
    Latestย  RT-BE92U Firmware 3.0.0.6_102_37500
    Firmware version 3.0.0.6_102_37500
    2/17/2025
    – Fixed CPU core full load issue.
    – Fixed connection issue after setting up VPN in Instant Guard.
    #35710
    • Replies 8,457
    New ASUS RT-BE92U Firmware version 3.0.0.6.102_37504
    Version 3.0.0.6.102_37504
    2025/02/21
    New Feature:
    – Added support for the v6Option WAN type.
    – Enhanced input parameter handling techniques to improve data processing stability and system security.
    – Enhance system access control mechanisms.
    #35740
    • Replies 8,457
    ASUS RT-BE92U Firmware version 3.0.0.6.102_37506
    Version 3.0.0.6.102_37506.
    2025/02/27.
    Stability and security enhancements.
    https://www.asus.com/uk/supportonly/rt-be92u/helpdesk_bios/?utm_source=asus-product&utm_medium=referral&utm_campaign=router
    #36329
    • Replies 8,457
    New RT-BE92U Firmware Firmware version 3.0.0.6_102_37523
    • Stability and security enhancements.
    #36735
    • Replies 8,457
    New RT-BE92U Firmware Firmware version 3.0.0.6_102_37526
    2025/04/02
    • Improved system stability
    https://www.asus.com/supportonly/rt-be92u/helpdesk_bios/?utm_source=asus-product&utm_medium=referral&utm_campaign=router%2F
    #37261
    • Replies 8,457
    RT-BE92U Firmware version 3.0.0.6_102_37548
    2025/04/21
    New Feature:
    Support 10G Hikari Cross (v6plus and OCN Virtual Connect)
    Support 10G DS-Lite (Xpass and transix)
    System stability improvements.
    https://www.asus.com/uk/supportonly/rt-be92u/helpdesk_bios/?utm_source=asus-product&utm_medium=referral&utm_campaign=router%2F
    #38141
    • Replies 8,457
    ASUS RT-BE92U Firmware version 3.0.0.6.102_37563
    Version 3.0.0.6.102_37563
    2025/06/27
    -Resolved an intermittent reboot issue occurring under specific conditions, with the underlying cause fixed.
    -Fixed reconnect issues in AiMesh mode.
    -Addressed multiple 5G channel issues with optimized exclusion rules.
    -Enhanced overall system stability.
    #39113
    • Replies 8,457
    ASUS RT-BE92U Firmware version 3.0.0.6.102_38961
    2025/08/15
    Security Enhancements:
    – Password Policy Upgrade โ€“ Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defence against brute-force attacks.
    – HTTPS on 8443 โ€“ Management interface now served over TLS by default.
    – UPnP Disabled โ€“ Universal Plug and Play starts in the off state for reduced surface exposure.
    – AiCloud Authentication Hardening (CWE-287) โ€“ Added layered verification.
    – Authentication Logic Refactor โ€“ Removed redundant code paths for a lean sign-in flow.
    – Memory Safety Guard (CWE-476) โ€“ Introduced null-reference protections across critical services.
    – Enhanced IPsec Parameter Validation โ€“ The existing input checks have been hardened.
    – Data Exposure Mitigation (CWE-200) โ€“ Reinforced controls on sensitive pathways.
    – Detailed Audit Trails โ€“ Expanded logging within the authentication module.
    System Improvements:
    – System Stability โ€“ Reduce reboot occurrences.
    – Connection Stability โ€“ Core algorithms refined for steadier links.
    – Scheduling Accuracy โ€“ Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
    – Client List Maintenance โ€“ Resolved an issue that prevented offline devices from being removed from the client list
    #40015
    • Replies 8,457
    ASUS RT-BE92U Firmware version 3.0.0.6.102_38979
    2025/10/31
    Changelog:
    – Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
    – Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
    #40296
    • Replies 8,457
    ASUS RT-BE92U Firmware version 3.0.0.6.102_38980
    2025/11/18
    – Release Note –
    – Improved network disconnection issue
    – Enhanced Wi-Fi stability
    #42281
    • Replies 8,457
    For those following this thread, I have spoken with ASUS regarding when the next firmware release for the RT-BE92U might be, response below:
    Firmware validation and release are in progress.
    The new firmware notification should be coming in the near future.
    #42313
    • Replies 8,457
    ASUS RT-BE92U Firmware version 3.0.0.6.102_39061
    2026/04/01
    Improvements:
    – Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
    – Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
    – Refined accessibility-related UI and interaction details.
    – Enhanced stability for 2.5G LAN/WAN port operations.
    – Improved overall remote connection stability.
    – Improved system behavior when using System diagnostic on feedback page.
    Bug Fixes:
    – Fixed incorrect connection status display for certain Wi-Fi devices.
    – Fixed AiMesh nodes not displayed correctly in the device list.
    – Fixed a disconnection issue that occurred after enabling the MAC Filter.
    – Fixed main network connectivity issue when enabling IPv6 for both the main network and Smart Home Master.
    – Strengthened input sanitization mechanism.
    – Enhanced system API validation for stronger protection consistency.
    – Strengthened command handling and system resource access controls.
    – Improved system logging and security event recording mechanisms.
Close โœ–
Search forums
Advanced forum search
Back to basic search
