ASUS ZenWiFi XT9 – Official Thread Latest firmware for the ASUS ZenWiFi XT9 – Version 3.0.0.4.388.21069 2022/09/28 ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388.21069 1. Fixed Samba file system clutter bug. 2. Improved AiMesh system backhaul TXBF…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi XT9 – Official Thread Latest firmware for the ASUS ZenWiFi XT9 – Version 3.0.0.4.388.21069 2022/09/28 ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388.21069 1. Fixed Samba file system clutter bug. 2. Improved AiMesh system backhaul TXBF...
Viewing 15 posts - 1 through 15 (of 28 total)
  • #21491
    2022/09/28
    2. Improved AiMesh system backhaul TXBF speed.
    3. Fixed AiProtection bug.
    4. Security
    – Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
    – Fixed status page HTML vulnerability. Thanks to David Ward.
    – Fixed CVE-2018-1160. Thanks to Steven Sroba.
    – Fixed cfg_server security issue.
    https://dlcdnets.asus.com/pub/ASUS/wireless/ZenWiFi_XT9/FW_ZENWIFI_XT9_300438821069.zip
    MD5: b98f5339e91b1a457ab7ac9394fcb3a8
    #21635
    ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388.21429
    2022/11/09
    1. Fixed AiMesh prelink issue.
    2. Improved system stability.
    3. Fixed 2.5GbE port compatibility issue.
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-xt9/helpdesk_bios/
    #21968
    ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388.21963
    1. Fixed IPTV compatibility issue with Movistar. Thanks to Sergio de Luz from RedesZone.net.
    2. Fixed VPN fusion, AiMesh, and Network map GUI bugs.
    3. Fixed WAN compatibility issue with Starlink router.
    4. Fixed miniupnpc vulnerabilities, CVE-2015-603, CVE-2017-1000494
    5. Fixed IPSec server vulnerability, CVE-2022-40617
    6. Improved connection speed with Verizon FIOS.
    Version 3.0.0.4.388.21963
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-xt9/helpdesk_download/
    #22300
    TomThumbTomThumb
    • Replies 31
    ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388.22068
    Version 3.0.0.4.388.22068 48.13 MB
    1. Improved system stability.
    2. Fixed the IPsec VPN compatibility issue with Win10.
    3. Fixed the VPN fusion user interface issues under the HTTPS connection.
    4. Fixed Client DOM Stored XSS vulnerability.
    5. Improved Wireguard performance.
    This 22068 release has been out less than 24Hrs & reports of system instability are all ready surfacing!
    Tom…
    #22301
    That does not sound promising but thanks for the information, a release to avoid maybe    😪
    #22302
    TomThumbTomThumb
    • Replies 31
    As is the norm lately, the router had announced that new firmware was available before if went live via the Asus website,
    I did some Google searches further afield from the UK on the 22068 fw for validation & came across the reports of the instability issues,
    tho it appears Asus have the used the same version # for both the XT8 & XT9,
    so the reports of instability issues I landed on came from both variants.
    Tom…
    #22304
    That is normal for ASUS for similar models, if you check the change logs for both the XT8 and XT9, for Firmware version 3.0.0.4.388.22068 they read exactly the same, so same fixes and same bugs shared across both models on this occasion
    I did read traffic analyzer still not working which would be annoying if this was true ?
    #22957
    • Replies 634
    My family member has 2 XT9’s in their house and wants to add an additional XT8 to the mesh network.  Are there any downside/issues to doing this?
    #22959
    Usually better from a mesh perspective to keep all mesh nodes the same if possible, but in theory no problem adding an addition XT8 to an existing XT9 mesh.
    Note: just try to ensure firmware are of the same release version if at all possible for each AiMesh node .
    TBH: – As long as the addition XT8 is not used as the primary (master), (XT8 has a slightly slower CPU and has  slightly slower WiFi 6 (802.11ax) (5GHz-1) up to 1201 Mbps throughput due to it not supporting 160MHz channel).
    ‘Hardware Specs:’
    The ASUS XT8 has 1.5 GHz ( 4 cores ) and 512 MB RAM
    ASUS XT9 has 1.7 GHz ( 4 cores)  CPU and 512 MB RAM
    Wifi Specs. ZenWiFi XT9 ZenWiFi XT8
    2.4GHz Wi-Fi Specs 2 x 2 AX
    Up to 574 Mbps
    (20/40MHz)
    2 x 2 AX
    Up to 574 Mbps
    (20/40MHz)
    5GHz-1 Wi-Fi Specs
    (channel width)
    2×2 AX
    Up to 2402Mbps
    (20/40/80/160MHz)
    2×2 AX
    Up to 1201Mbps
    (20/40/80MHz)
    5GHz-2 Wi-Fi Specs 4×4 AX
    Up to 4804Mbps
    (20/40/80/160MHz)
    4×4 AX
    Up to 4804Mbps
    (20/40/80/160MHz)
    Note1: ASUS XT8 is supported by ASUSWRT-Merlin (GNUTON) and XT9 is not, I believe.
    #22960
    • Replies 634
    Looks like the 5GHz-2 are the same spec on XT8 and XT9.  Only difference is impoved 5GHZ-1 spec.
    #22961
    TomThumbTomThumb
    • Replies 31
    Asus do state,
    AiMesh connects multiple compatible ASUS routers to create a whole-home mesh WiFi network. The flexible and scalable technology lets you mix different AiMesh-compatible routers, and add new ones at any time to improve coverage.* All devices in an AiMesh network enjoy access to all the features of the main router, including gaming features, AiProtection commercial-grade security and more. Most ASUS routers already support AiMesh.
    The only issue I can foresee, is if Asus releases radical changes to firmware between the 2 models,
    otherwise all AI mesh routers should play nice together ????
    Tom…
    #22963
    [quote quote=22960]Looks like the 5GHz-2 are the same spec on XT8 and XT9. Only difference is impoved 5GHZ-1 spec.[/quote]
    5GHz-2 are same spec for both XT8 and XT9, seems ASUS upgraded 5GHz-1 chipset for the XT9
    #22966
    [quote quote=22961]otherwise all AI mesh routers should play nice together ????[/quote]
    #30751
    New ASUS ZenWIFI XT9 Firmware version 3.0.0.4.388_24609
    Version 3.0.0.4.388_24609
    2024/01/26
    Bug Fixes and Enhancements:
    – Fixed IP display list issue on networkmap.
    – Fixed a GUI bug for WireGuard client profile name.
    – Fixed WAN connection issues.
    – Resolved OpenVPN server TAP mode issue.
    – Added MTU setting for WireGuard client.
    – Ensured consistent display of client status on the WireGuard server.
    – Enhanced system stability when accessing the WireGuard server with DMZ enabled.
    – Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
    – Fixed AiMesh node under Ethernet backhaul issues.
    – Fixed GUI bugs while searching for AiMesh Node.
    – Fixed USB function related issues.
    – Fixed a GUI bug that occurred when adding port range rules in the Network Service Filter.
    Security Fixes:
    – Fixed command injection vulnerabilities.
    – Upgraded to the latest dropbear version.
    – Fixed a stack overflow vulnerability.
    – Fixed vulnerability in command injection after authentication.
    – Fixed XSS potentially via malformed hostname in DHCP request.
    https://www.asus.com/uk/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-xt9/helpdesk_bios?model2Name=ASUS-ZenWiFi-XT9
    #34127
    Latest ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24668
    Version 3.0.0.4.388_24668
    2024/09/23
    1. Optimized memory management mechanisms, improving system efficiency and stability.
    5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
