› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi XT9 – Official Thread Latest firmware for the ASUS ZenWiFi XT9 – Version 3.0.0.4.388.21069 2022/09/28 ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388.21069 1. Fixed Samba file system clutter bug. 2. Improved AiMesh system backhaul TXBF...
- This topic has 27 replies, 3 voices, and was last updated 4 weeks, 1 day ago by
November 7, 2024 at 5:22 am #34765
ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24684
Version 3.0.0.4.388_24684
2024/11/05
Changelog:
6. Strengthened certificate protection, providing enhanced data security.You need to login in order to vote
March 14, 2025 at 2:11 pm #35990New ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24709
2025/03/13
4. Enhance system access control mechanisms.You need to login in order to vote
April 23, 2025 at 7:39 pm #37292ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24710
2025/04/22
- Improved compatibility with certain IoT devices.
October 20, 2025 at 5:52 pm #39866ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24768
2025/10/20
– Enhanced system stability.
– Addressed multiple security weaknesses in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
– Fixed a privilege escalation vector in the IFTTT token exchange mechanism
– Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.You need to login in order to vote
May 16, 2026 at 10:12 am #42706New firmware for XT9 15/5/26
ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24814
Looks like the zip file for the latest firmware is corrupted, it won’t unpack correctly.
Tom
May 16, 2026 at 11:33 am #42707I just checked and also had issues when attempting to extract/unpack this firmware package.
FW_ZENWIFI_XT9_300438824814.zip
I’ll drop ASUS a message and see if they can replace asap
May 16, 2026 at 12:12 pm #42708Appreciated 👍
New firmware has been released for a few models over the past few days but only reports exist for the XT9 suggesting it’s not widespread.
Tom
May 16, 2026 at 12:17 pm #42709May 18, 2026 at 11:06 am #42714re-released ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24814 and corruption has been fixed
2026/05/18
Security Fixes:
– Enhanced DNS name handling to address a potential memory issue that could occur in rare cases during name format conversion, improving system security and robustness.
– Improved safeguards for execution modules to reduce the risk of substitution during certain processes.You need to login in order to vote
May 18, 2026 at 12:02 pm #42715May 18, 2026 at 12:23 pm #42716August 5, 2026 at 8:59 pm #43131ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24854
2026/08/04
Security Fixes
– Strengthened verification when a software component downloads – external resources, improving connection security.
– Improved data-display handling in a web function to enhance browsing security.
– Strengthened data handling in the system logging function.We recommend upgrading to this version to maintain optimal protection.
October 21, 2026 at 4:44 pm #44541ASUS ZenWiFi XT9 Firmware version 3.0.0.4.388_24911
2026/10/20
Fixed an issue that could cause DNS resolution failures and loss of Internet access when DNSSEC is enabled.Security Fixes:
AiMesh: Adjusted data access protection during the node joining process, improving system stability while connections are being established.System temporary directory: Adjusted the default permissions applied at creation time to narrow local file access.
Network diagnostic data query: Added allowlist validation for query fields.Internal data query: Improved field matching logic and optimized the memory release process under error conditions.
System configuration file generation: Strengthened parameter content checks to prevent abnormal configuration values from affecting network service settings.VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
