Buying 2nd hand iPad So if you are looking to purchase a second hand iPad, make sure…. Need to check that the device is unlocked and not stolen. Legitimate owners usually keep their purchase…
› UKTH forums › 📱 Mobile › iPads › Buying 2nd hand iPad So if you are looking to purchase a second hand iPad, make sure…. Need to check that the device is unlocked and not stolen. Legitimate owners usually keep their purchase...
  • #12490
    • Replies 8,702
    • Need to check that the device is unlocked and not stolen. Legitimate owners usually keep their purchase receipts.
    • Check for screen and case damage and in particular minor scratches may not effect screen usage but can be used to lower asking price ?
    • Launch a few apps, including the Notes app, which gives you an opportunity to use the on-screen keyboard. If you have Wi-Fi access, open the Safari web browser and go to several websites.
    • Plug the iPad into a wall outlet and confirm the battery icon in the upper-right corner shows a lightning bolt, which means it is charging. This indicates the port at the bottom of the iPad is in good working order.
    Any other suggestion ?
