DSL-AC68U on Merlin / CLI commans Hi – I have the above mentioned router on Firmware Version:384.17_0-gnuton1 I’m trying to affect my maxDataRate, but the CLI is not working, please can someone help? I’m connected to…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › DSL-AC68U on Merlin / CLI commans Hi – I have the above mentioned router on Firmware Version:384.17_0-gnuton1 I’m trying to affect my maxDataRate, but the CLI is not working, please can someone help? I’m connected to...
  • #9167
    Avatarlmg80
    • Replies 5
    I’m connected to my router via Putty 192.168.1.1, followed by telnet 169.254.0.1.
    I get to the tc> on the command prompt and tried the below commands, but I get “……..:not found”
    xdslcmd configure –maxDataRate 60000 15000 100000
    xdslctl configure –maxDataRate 60000 15000 100000
    bcm_xdslctl configure –maxDataRate 60000 15000 100000
    #9170
    • Replies 8,705
    (I moved this post to the  @GNUton folder)
    Welcome, is your DSL-AC68U plugged into a DSL line and working currently ?
    Try using LAN port 4 first to see if you can gain access, ?
    Edit: I forgot to ask, the DSL-AC68U has a troublesome Modem (MediaTeK) and G.inp for instance is not supported by BT (Plusnet) when using the DSL-AC68U –  so lower synch rates etc ?
    #9172
    Avatarlmg80
    • Replies 5
    Thank you for taking your time to reply.
    Yes, I currently have an up/downlink.
    Excuse my ignorance ‘lan port 4’; is this the telnet/ssh port I define in the UI, currently default 23?
    Or you mean the lan port back ‘4’ on the router my PC is connected too?
    Edit: pc connected to LAN port 4, same thing :(
    #9175
    • Replies 8,705
    Does the putty cmd connect to router (192.168.1.1) and can you login (authenticate) etc?
    #9176
    Avatarlmg80
    • Replies 5
    Yes I can log into putty / land here post entering admin/password
    ASUSWRT-Merlin DSL-AC68U 384.17_0-gnuton1 Sat May 2 06:41:59 UTC 2020
    admin@DSL-AC68U-5ED0:/tmp/home/root#
    I then enter ‘telnet 169.254.0.1’ admin /password – land here (this is where I am entering the commands)
    Entering character mode
    Escape character is ‘^]’.
    tc login: admin
    Password:
    tc>
    #9177
    • Replies 8,705
    I am being a little slow, these are Broadcom based CMDS and the DSL-AC68U uses a MediaTeK DSL Chipset
    I will dig out my DSL-AC68U tonight and find the cmds you need ;-)
    #9178
    Avatarlmg80
    • Replies 5
    Thank you buddy, yeah I came to the same conclusion; very much appreciate your help :)
    #9179
    Avatarlmg80
    • Replies 5
    I’ve tried these, that whilst they are accepted, they do not actually do anything – unless they should be preceded by a save, or reboot?
    wan dmt2 set snrmoffset xx xx (snr tweak)
    wan dmt2 set path x (0-2 channel profile fast interleaved)
    wan adsl reset
    wan vdsl2 set target_snrm xx (snr tweak vdsl2)
    wan vdsl2 set max_ds_rate xx (something about data rate)
    wan vdsl2 set manual_pms on/off (something about channel profile)
    wan vdsl2 set inpdelay_pms xx (same ^)
    wan vdsl2 set tcm_tx on/off (idk)
    wan vdsl2 set tcm_rx on/off (idk)
    #9180
    • Replies 8,705
    Can you try – just want to see if it works ? should give us your DSL stats
    cat /tmp/adsl/info_adsl.txt
    #9182
    • Replies 8,705
    try the below, I have also dropped ASUS an email and they say it cannot be done, so am a little miffed by what they said ?
    wan vdsl2 set max_ds_rate ‘value’  (value = kbps ÷  8) 80000kbps ÷  8  then value  input = 10000
    Trick is I do not think this will survive a reboot and does not work on ADSL connections I believe
    MediaTeK DSL ()
