ASUS DSL Legacy (EOL) Firmwares ASUS DSL Legacy (End-of-Life) Firmware’s, OK, so it took me a little time to organise but finally managed to extract from those kind chaps at the ASUS DSL Team, the…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS DSL Legacy (EOL) Firmwares ASUS DSL Legacy (End-of-Life) Firmware’s, OK, so it took me a little time to organise but finally managed to extract from those kind chaps at the ASUS DSL Team, the...
Viewing 15 posts - 31 through 45 (of 73 total)
  • #12780
    [quote quote=12779]I have emailed you with download links and normal UKTechHub.com ASUS Beta T&Cs apply[/quote]
    I have emailed you with download link and normal UKTechHub.com ASUS Beta T&Cs apply
    #13820
    Jamie DavisJamie Davis
    • Replies 2
    Hey UK Sentinel
    i have been running the firmware for a few months now and it got some awesome features however do you know why after about 19hrs of being on, the router becomes unresponsive on the web interfaces but is fine if you connect devices to wifi or ethernet but the web index page and app no longer communicate and it stops all my port forwarding rules to my devices. Everything can connect out to the internet while it is in crashed state so i have set the router to auto reboot at 3 am every morning but i would love to get this issue sorted.
    after it is in crashed state only way i can communicate with it is use putty and ssh to the router and run reboot command
    i have stopped the dhcp server on the router also as i have a Pi-hole running next to it and that does all the assigning i have only just made this change so i will update if it still has issues
    Kind Regards
    Jamie
    #13821
    How high gets memory usage before it stops working, often caused by a memory leak maybe only when you use a special feature like AI-protection or QoS.
    #13822
    Good to hear the  DSL-N66U is still going strong
    As @Grisu details, keep an eye on RAM usage and see if that keeps increasing upto 19 hours etc.
    Also try a different browser, just to make sure then if that fails try the below
    I would if possible try a factory reset and rebuild router from scratch (not backup) and hopefully that will clear any issues and then see if that helps ?
    I have not seen issues with access to DSL-N66U mentioned on this forum, so hopefully just unique to yourself
    #14277
    AvatarTrillian796
    • Replies 1
    Hi UK Sentinel,
    I’m pleased I found this site as have been wondering for a whilee where I could get an update.
    Many thanks for obtaining and providing these , it is much appreciated :-)
    Please could you send me the firmware Beta for the DSL-N66U.
    Thank you
    #14281
    [quote quote=14277]Hi UK Sentinel, I’m pleased I found this site as have been wondering for a whilee where I could get an update. Many thanks for obtaining and providing these , it is much appreciated :-) Please could you send me the firmware Beta for the DSL-N66U. Thank you[/quote]
    Welcome and glad you found us, I have sent you an email
    #14359
    AvatarDisturbed
    • Replies 1
    Hello, i have no idea why i couldnt discover this forum before :)
    Can i also have a link for DSL-N66U beta firmware please ?
    Thanks in advance
    #14360
    [quote quote=14359]Hello, i have no idea why i couldnt discover this forum before :) Can i also have a link for DSL-N66U beta firmware please ? Thanks in advance[/quote]
    Glad you found us and I have sent you an email
    #14728
    AvatarU-StaSS
    • Replies 1
    Hi.
    Is it possible to send me a link for latest DSL-N17U beta firmwares or post them here?
    Tnx
    #14730
    [quote quote=14728]I have emailed you with download link and normal UKTechHub.com ASUS Beta T&Cs apply[/quote]
    #15439
    AvatarSilverbob76
    • Replies 1
    Hi
    can you please send me a downloadlink for ASUS DSL N12E C1?
    By the way, any idea how i can set up as repeater? I cant find the repeater mode on this router.
    Thx
    Regards, silverbob76
    #15440
    Welcome, I have emailed you with download link and normal UKTechHub.com ASUS Beta T&Cs apply
    Repeater mode, I don’t think that option is supported on this model, but if it is try the blow option.
    Go via ASUS Quick Internet Setup (manual settings) – then run through the UI, at the Internet Setup page there should be Repeater mode option.
    Edit: there is a manual work around if indeed Repeater mode is not available, but only for Ethernet backhaul I believe.
    #17518
    Avatarmrcoco
    • Replies 1
    please can you send me the new download link ASUS DSL-N66U Firmware
    thanks
    #17526
    [quote quote=17518]please can you send me the new download link ASUS DSL-N66U Firmware thanks[/quote]
    #18206
    AvatarPeteBest
    • Replies 2
    So it looks like ASUS have removed the dl from their website for the last firmware and the one I just got 2nd hand is failing to boot properly. Any chance I could get the dl link for the last beta version to try recovery?
    Thanks!
