DSL Modem/Router Recommendations
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › DSL Modem/Router Recommendations
Viewing 15 posts - 91 through 105 (of 141 total)
  • #13101
    [quote quote=13099]I thought that had sorted it – factory reset of the vigor. When it started up the PC registered as being connected but just as quickly disconnected again. Now the router shows as connected, but the PC not. I’ve been at this for hours now![/quote]
    Reboot PC to see if it gets a new IP address, if no luck then reboot ASUS, if all else fails follow below …
    Now factory reset the ASUS router and use the QIS,
    btw- do you know what firmware version the Draytek 130 is running ?
    #13102
    Great, thanks for your help!
    Fingers crossed it comes tomorrow, had to get from 2 different places..
    Avatarpavlf
    • Replies 70
    I’m giving that a go. None of my devices will connect at the moment. It’s only been four hours so far …
    #13104
    What’s the best way to update the firmware on the Draytek 130? Can I plug a cable from lan port into existing network and access it and update it or so I simply unplug BT router, connect up the modem to the BT socket, plug a computer into the lan port on modem and update?  Then once done, then plug in the ASUS router?
    or plug in the modem tot BT socket, connect up the ASUS router and then enter in BT username in Asus router and let it all connect up and then update the modem after?
    Looks like the last firmware for 130 came out in Oct 2019 so fingers crossed it comes with latest version, can’t imagine they have had them sitting on the shelf for 1.5 years?
    [quote quote=13105]Looks like the last firmware for 130 came out in Oct 2019 so fingers crossed it comes with latest version, can’t imagine they have had them sitting on the shelf for 1.5 years? Kev[/quote]
    #13107
    Avatarpavlf
    • Replies 70
    Factory reset both router and modem, given static IP to PC, no joy. Chrome says DNS problem. I’ve set the router to use Google’s DNS.
    In the Draytek MPoA is disabled. I’m guessing this ought to be enabled, not PPPoE? I’m just swapping that around to see that brings any joy. It does seem to have worked! Hooray. But whilst I’ve not got a functioning internet the new problem is that the Draytek has become inaccessible via 192.168.2.1 . What fun,
    #13108
    Avatarpavlf
    • Replies 70
    Sorry that should read ‘now got’ – the internet is working. Thanks so much for the tips. I was getting towards pulling my hair out. I cope without accessing the modem for a while. I guess it will end up bugging me though
    #13109
    Great news, so for TalkTalk, swapping on the Vigor 130 from PPPOE to MPoA did the trick ?
    Try running on the PC’s CMD Line (tracert bbc.co.uk) and see if the modems IP address has changed (2nd hop)
    #13111
    Avatarpavlf
    • Replies 70
    Yes, that’s what worked for me. Not sure how stable everything is. The modem seems to be up, but the router has disconnected a couple of times. I’ll try what you suggest later on after work. Thanks again for your help, much appreciated
    #13112
    Avatarpavlf
    • Replies 70
    Results …
    #13114
    [quote quote=13111]Yes, that’s what worked for me. Not sure how stable everything is. The modem seems to be up, but the router has disconnected a couple of times. I’ll try what you suggest later on after work. Thanks again for your help, much appreciated[/quote]
    Shame, I had hoped your Modem IP address maybe visible,
    #13116
    [quote quote=13104]What’s the best way to update the firmware on the Draytek 130? Can I plug a cable from lan port into existing network and access it and update it or so I simply unplug BT router, connect up the modem to the BT socket, plug a computer into the lan port on modem and update? Then once done, then plug in the ASUS router? or plug in the modem tot BT socket, connect up the ASUS router and then enter in BT username in Asus router and let it all connect up and then update the modem after? Kev[/quote]
    Got my modem and router today, what’s the best way to set it up?  Set it all up as is and then update firmware, providing can reach modem web gui from PC and router routes it?
    Avatarpavlf
    • Replies 70
    I plugged mine into the socket and then a laptop, the update button is in the GUI. Once done I then plugged in the router. It’s all running swimmingly at the moment. After the dsl ac88u it’s like a dream.
    #13118
    Congrats, to keep it simple, you could download the latest Vigor 130 from below link and update the modem whilst offline, then you can plug it into DSL Master Socket and job done.
    (or try as @pavlf details) never tried it that way but sounds easier
    https://www.draytek.co.uk/support/downloads/vigor-130
    Use the recommended Firmware (3rd in list) Vigor 130 3.8.4.1 BT Firmware – RecommendedDownloadSize 11.7 MB
