Viewing 15 posts - 31 through 45 (of 1,130 total)
  • #1721
    Avatarampthetex
    • Replies 10
    [quote quote=1720]Try the other options in my above post, especially the MTU etc?[/quote]
    Ok, I shall give them a blast.
    #1722
    Avatarampthetex
    • Replies 10
    I reset the box, hard reset on the box, let it find an uplink, then started the wizard, it went through, left it while I did the dishes come back and the exclamation mark had gone, and we was on, but Im getting less than 20mbps, when it should be around 66mbps.
    Thanks for the advice
    #1723
    • Replies 8,717
    Need to buy yourself a new toy ;-)
    If you can give us a screen dump of the DSL General and DSL LOG page, so  we can see what is going on?
    #1725
    Avatarampthetex
    • Replies 10
    I connected via the 5G WiFi insead of the 2.4GHz and bingo we’re back in business.
    #1726
    • Replies 8,717
    [quote quote=1725]I connected via the 5G WiFi insead of the 2.4GHz and bingo we’re back in business.[/quote]
    That is good news issue is only 2.4GHZ wifi, is that with Stock or beta firmware, and did you end up just using the default set-up options, or was tweaking required?
    Hopefully this will help others?
    #1729
    Avatarport3r
    • Replies 6
    Hi, first I would tell you, thanks for this forum. I’m owner of ASUS DSL-N66U. I have one question about your beta firmware. I use original firmware version 1.1.1.3. You recommended me to go to your beta firmware? How mainly reason is to switch to your beta? Thanks for all.
    #1730
    • Replies 8,717
    [quote quote=1729]Hi, first I would tell you, thanks for this forum. I’m owner of ASUS DSL-N66U. I have one question about your beta firmware. I use original firmware version 1.1.1.3. You recommended me to go to your beta firmware? How mainly reason is to switch to your beta? Thanks for all.[/quote]
    Welcome and thank you, the Beta firmware from this forum is supplied by ASUS and provides updates and fixes that are better (mostly) than original stock Firmware.
    The DSL-AC66U is now reached its EoL (End of Life) support, so ASUS are supporting this model going forward only with beta’s
    For changes/improvements in beta firmware’s,  check the changelog description as these articulate what changes have been made
    Hope that helps?
    #1731
    Avatarport3r
    • Replies 6
    Ooo, it’s made by ASUS? Super, It’s safe to use?
    What is the one of best or important things of this beta firmware?
    Avatarport3r
    • Replies 6
    It’s possible to use config file from 1.1.1.3 to new beta?
    #1735
    Avatarport3r
    • Replies 6
    One more time please, in system log is:
    Warning! MAC addr not equal to MII master => set MiiMasterMac
    What does it means?
    #1736
    • Replies 8,717
    [quote quote=1731]Ooo, it’s made by ASUS? Super, It’s safe to use? What is the one of best or important things of this beta firmware? Thanks[/quote]
    – KRACK patch: WPA2 security vulnerability issue(When the AP receives a retransmitted Message 2/4, it should check the WPA2 processing state. AP should ignore the Message 2/4 if the WPA2 security connection is done). Earlier KRACK patch specifically for ApClient/STA, now later paper by Mathy Vanhoef targets AP, thus need to adopt this additional patch.
    [quote quote=1731]It’s possible to use config file from 1.1.1.3 to new beta?[/quote]
    Yes, It is, best to upgrade via UI, download file and unzip, the go to (UI) Advanced Settings > Administration > Firmware Upgrade and select downloaded file
    #1737
    • Replies 8,717
    [quote quote=1735]One more time please, in system log is:
    What does it means?[/quote]
    After you have updated to latest firmware, then see if message is still being created, the error message is related to a specific MAC Address and  Data interface to the Ethernet MAC,  for sending and receiving Ethernet frame data (I believe) but hopefully firmware upgrade will remove problem
    #1738
    Avatarport3r
    • Replies 6
    Thanks for all, I will give you a response…
    #1747
    Avatarport3r
    • Replies 6
    Woalaaaa, thank you! I’ve got new beta firmware on my N66U device.
    Everything works well.
    Thank you so much again.
    Juraj from Slovakia
    #1748
    • Replies 8,717
    [quote quote=1747]Woalaaaa, thank you! I’ve got new beta firmware on my N66U device. Everything works well. Thank you so much again. Juraj from Slovakia[/quote]
