Viewing 15 posts - 16 through 30 (of 1,130 total)
  • #1665
    Avatarampthetex
    • Replies 10
    Hi, Yes. When it got to 100% and says complete, I go into other room, stick a paperclip in reset button hole for 5-10 secs, then release, then go back and when its all kicked back in I try to setup via wizard via long lan cable. I’m back using the Sky bog standard router at the moment, I’ll try again later on, and I’ll take some screenshots etc.
    Cheers
    Steve
    #1666
    • Replies 8,738
    Maybe also worth when using stock firmware, take a back-up of the config and after loading latest Beta firmware, then load backup.cfg file and give router a reboot?
    Hopefully one of these options will work?
    #1699
    Avatarmarshy61
    • Replies 2
    Hello, I want to upgrade my firmware but i have some questions.
    Can i return the old stock firmware if i upgrade beta ones?
    Also am i going to lose my warranty with these firmwares?
    Thanks.
    #1701
    • Replies 8,738
    [quote quote=1699]Hello, I want to upgrade my firmware but i have some questions. Can i return the old stock firmware if i upgrade beta ones? Also am i going to lose my warranty with these firmwares? Thanks.[/quote]
    As all the firmware’s (Betas) are from ASUS, then firmwares can be upgraded/downgraded etc,
    Warranty will not be effected as warranties usually cover hardware mainly? and if for any reason you have to/wish to return router, then best to flash back to a stock firmware, just to be safe.
    #1705
    Avatarampthetex
    • Replies 10
    You cant point me in the direction of the stock firmware can you please, they seem to not be on the ASUS site anymore.
    Cheers
    Steve
    #1708
    • Replies 8,738
    I have dropped ASUS an email to ask where the Stock Firmware’s are located nowadays, I thinks as the DSL-N66U is old, they have probably taken them offline, but will let you know if I get a response from ASUS.
    #1709
    Avatarampthetex
    • Replies 10
    Hi, That is very kind of you, thank you.
    #1710
    Avatarmarshy61
    • Replies 2
    I found a firmware for dsl-n66u. 08.07.2016 -> release date
    #1712
    • Replies 8,738
    [quote quote=1710]1.1.1.3 I found a firmware for dsl-n66u. 08.07.2016 -> release date[/quote]
    #1713
    • Replies 8,738
    [quote quote=1709]Hi, That is very kind of you, thank you.[/quote]
    I had a response back from ASUS, it looks like when products reach End of Life (EOL) the firmware are automatically removed from site, but ASUS do continue to support EOL DSL Products via beta releases .
    After checked internally, I am afraid this model already EOL for many years, thus no longer supported and firmware removed from support site.
    However, as you know beta updated firmware available, as follows.
    v9.1.2.3_617-gfa1b634
    https://www.asuswebstorage.com/navigate/s/FD6779114D6641B8A78A7A0B4571AB22Y
    #1715
    Avatarampthetex
    • Replies 10
    Right, Ive flashed it, reset it, flashed it, and reset it about half a dozen times lol. I have managed to get it to see the DSL connection with the beta firmware, and its showing data going back and forth.
    But, it says no internet, so Im thinking its an authentication problem, Ive tried using the DHCP box, and using the option 60, and even option 61 which I sniffed out from the Sky router, but still nothing.
    Here’s my log from when I had some sort of connection
    2011-01-01 00:01:05 [Informational] stop_nat_rules: apply the redirect_rules!
    2011-01-01 00:01:06 [Informational] kernel: Firmware version=[v9.1.2.3]
    2011-01-01 00:01:07 [Informational] kernel: Link State: DSL link up.
    2011-01-01 00:01:07 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:01:07 [Informational] kernel: usbcore: registered new interface driver usbfs
    2011-01-01 00:01:07 [Informational] kernel: usbcore: registered new interface driver hub
    2011-01-01 00:01:07 [Informational] kernel: usbcore: registered new device driver usb
    2011-01-01 00:01:07 [Notice] kernel: SCSI subsystem initialized
    2011-01-01 00:01:08 [Informational] kernel: Initializing USB Mass Storage driver…
    2011-01-01 00:01:08 [Informational] kernel: usbcore: registered new interface driver usb-storage
    2011-01-01 00:01:08 [Informational] kernel: USB Mass Storage support registered.
    2011-01-01 00:01:09 [Notice] kernel: ufsd:: trace mask set to 0000000f
    2011-01-01 00:01:09 [Notice] kernel: ufsd: driver (UFSD_HEAD lke_8.9.0_r209178_b9, LBD=ON, acl, ioctl, sd, wb, tr) loaded at c02f1000
    2011-01-01 00:01:09 [Informational] kernel: NTFS support included
    2011-01-01 00:01:09 [Informational] kernel: Big endian platform
    2011-01-01 00:01:09 [Informational] kernel: optimized: speed
    2011-01-01 00:01:09 [Informational] kernel: Build_for__ASUS_PRODUCTS_001_k2.6.22.15_2012-12-24_lke_8.9.0_r209178_b9
    2011-01-01 00:01:10 [Informational] kernel: PCI: Enabling device 0000:02:03.3 (0000 -> 0002)
    2011-01-01 00:01:10 [Informational] kernel: ehci_hcd 0000:02:03.3: EHCI Host Controller
    2011-01-01 00:01:10 [Informational] kernel: ehci_hcd 0000:02:03.3: new USB bus registered, assigned bus number 1
    2011-01-01 00:01:10 [Informational] kernel: ehci_hcd 0000:02:03.3: irq 21, io mem 0x1fba1000
    2011-01-01 00:01:10 [Informational] kernel: ehci_hcd 0000:02:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
    2011-01-01 00:01:10 [Informational] kernel: usb usb1: configuration #1 chosen from 1 choice
    2011-01-01 00:01:10 [Informational] kernel: hub 1-0:1.0: USB hub found
    2011-01-01 00:01:10 [Informational] kernel: hub 1-0:1.0: 2 ports detected
    2011-01-01 00:01:10 [Debug] kernel: ohci_hcd: 2006 August 04 USB 1.1 ‘Open’ Host Controller (OHCI) Driver
    2011-01-01 00:01:10 [Informational] kernel: PCI: Enabling device 0000:02:03.0 (0000 -> 0002)
    2011-01-01 00:01:10 [Debug] kernel: PCI: Setting latency timer of device 0000:02:03.0 to 64
    2011-01-01 00:01:10 [Informational] kernel: ohci_hcd 0000:02:03.0: OHCI Host Controller
    2011-01-01 00:01:10 [Informational] kernel: ohci_hcd 0000:02:03.0: new USB bus registered, assigned bus number 2
    2011-01-01 00:01:10 [Informational] kernel: ohci_hcd 0000:02:03.0: irq 24, io mem 0x1fba0000
    2011-01-01 00:01:11 [Informational] kernel: usb usb2: configuration #1 chosen from 1 choice
    2011-01-01 00:01:11 [Informational] kernel: hub 2-0:1.0: USB hub found
    2011-01-01 00:01:11 [Informational] kernel: hub 2-0:1.0: 2 ports detected
    2011-01-01 00:01:11 [Informational] kernel: usbcore: registered new interface driver usblp
    2011-01-01 00:01:11 [Informational] kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
    2011-01-01 00:01:13 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:01:13 [Informational] kernel: usbcore: registered new interface driver asix
    2011-01-01 00:01:13 [Informational] kernel: nas8: starting interface.
    2011-01-01 00:01:14 [Informational] kernel: usbcore: registered new interface driver cdc_ether
    2011-01-01 00:01:14 [Informational] kernel: usbcore: registered new interface driver rndis_host
    2011-01-01 00:01:14 [Informational] kernel: cdc_ncm: 14-Mar-2012
    2011-01-01 00:01:14 [Informational] kernel: usbcore: registered new interface driver cdc_ncm
    2011-01-01 00:01:14 [Informational] kernel: usbcore: registered new interface driver cdc_wdm
    2011-01-01 00:01:14 [Informational] kernel: cdc_mbim: loaded
    2011-01-01 00:01:14 [Informational] kernel: usbcore: registered new interface driver cdc_mbim
    2011-01-01 00:01:15 [Informational] rstats[2666]: [start rstats]
    2011-01-01 00:01:24 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:01:26 [Informational] kernel: [wan_execute]cur_vc=0, isAdslOrVdsl=2
    2011-01-01 00:01:26 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:02:49 [Informational] kernel: new sra = on
    2011-01-01 00:02:49 [Informational] kernel: US bitswap on,DS bitswap on
    2011-01-01 00:02:49 [Informational] kernel: Set SNRM OFFSET = 0.0 db
    2011-01-01 00:02:49 [Informational] kernel: Set Agc Vref1 = 65535 ; Vref2 = 65535 ; Vref3 = 65535
    2011-01-01 00:02:49 [Informational] kernel: new target_snrm = 32767
    2011-01-01 00:02:49 [Informational] kernel: PROFILE30A_MULTI_MODE
    2011-01-01 00:02:49 [Informational] kernel: new agc_ref = 65535,65535,65535,65535
    2011-01-01 00:02:49 [Informational] kernel: cur upbo =1
    2011-01-01 00:02:49 [Informational] kernel: usage: wan vdsl2 set upbo [on|off]
    2011-01-01 00:02:49 [Informational] kernel: New sync sym update flag :OFF
    2011-01-01 00:02:49 [Informational] kernel: PHYR_NONE mode
    2011-01-01 00:02:49 [Informational] kernel: ANNEXAIJLM
    2011-01-01 00:02:50 [Informational] kernel: new sra = on
    2011-01-01 00:02:50 [Informational] kernel: US bitswap on,DS bitswap on
    2011-01-01 00:02:50 [Informational] kernel: Set SNRM OFFSET = 0.0 db
    2011-01-01 00:02:50 [Informational] kernel: Set Agc Vref1 = 65535 ; Vref2 = 65535 ; Vref3 = 65535
    2011-01-01 00:02:50 [Informational] kernel: new target_snrm = 32767
    2011-01-01 00:02:50 [Informational] kernel: PROFILE30A_MULTI_MODE
    2011-01-01 00:02:50 [Informational] kernel: new agc_ref = 65535,65535,65535,65535
    2011-01-01 00:02:50 [Informational] kernel: cur upbo =1
    2011-01-01 00:02:50 [Informational] kernel: usage: wan vdsl2 set upbo [on|off]
    2011-01-01 00:02:50 [Informational] kernel: New sync sym update flag :OFF
    2011-01-01 00:02:50 [Informational] kernel: G.inp mode
    2011-01-01 00:02:51 [Informational] kernel: ANNEXAIJLM
    2011-01-01 00:02:52 [Informational] kernel: Link State: DSL link down.
    2011-01-01 00:02:59 [Informational] WAN Connection: Wan link down.
    2011-01-01 00:03:38 [Informational] WEB: Configuration changed: SysInfo_Entry
    2011-01-01 00:03:43 [Informational] WEB: Configuration changed: Account_Entry0
    2011-01-01 00:03:43 [Informational] Samba Server: smb daemon is stoped
    2011-01-01 00:03:43 [Informational] FTP Server: daemon is stoped
    2011-01-01 00:03:44 [Informational] WEB: Configuration changed: SysInfo_Entry
    2011-01-01 00:03:44 [Informational] kernel:
    2011-01-01 00:03:45 [Informational] kernel:
    2011-01-01 00:03:45 [Informational] kernel: WPSActiveStatus = NULL
    2011-01-01 00:03:45 [Informational] kernel: WPSOOBActive = NULL
    2011-01-01 00:03:45 [Informational] kernel: ReCounterActive = NULL
    2011-01-01 00:03:45 [Informational] kernel: WPSGenPinCode = NULL
    2011-01-01 00:03:45 [Informational] kernel: write_wlan_AutoChannelSkipList -(0x20)
    2011-01-01 00:03:45 [Informational] kernel: write_wlan_AutoChannelSkipList – (DE)(0x8)
    2011-01-01 00:03:45 [Informational] kernel: Net device ra00_0 going down….
    2011-01-01 00:03:45 [Informational] kernel: rlk_inic_mbss_close —>
    2011-01-01 00:03:45 [Informational] kernel: rlk_inic_mbss_close <—
    2011-01-01 00:03:45 [Informational] kernel: iNIC Closed
    2011-01-01 00:03:46 [Informational] kernel: Net device ra01_0 going down….
    2011-01-01 00:03:46 [Informational] kernel: rlk_inic_mbss_close —>
    2011-01-01 00:03:46 [Informational] kernel: setup MBSS[0] success
    2011-01-01 00:03:46 [Informational] kernel: all interfaces closed.
    2011-01-01 00:03:46 [Informational] kernel: rlk_inic_mbss_close <—
    2011-01-01 00:03:46 [Informational] kernel: iNIC Closed
    2011-01-01 00:03:46 [Informational] kernel: Delete HeartBeatTimer ….
    2011-01-01 00:03:47 [Informational] kernel: iNIC Open ra00_0
    2011-01-01 00:03:47 [Informational] kernel: Op mode = 1
    2011-01-01 00:03:47 [Informational] kernel: Read profile[0]
    2011-01-01 00:03:47 [Informational] kernel: BssidNum=4
    2011-01-01 00:03:47 [Informational] kernel: Read profile[1]
    2011-01-01 00:03:47 [Informational] kernel: Wait for boot done…
    2011-01-01 00:03:49 [Informational] kernel: RACFG_CMD_BOOT_NOTIFY
    2011-01-01 00:04:10 [Informational] kernel: Open file: /etc/Wireless/RT6856/iNIC.bin
    2011-01-01 00:04:10 [Informational] kernel: RACFG_CMD_BOOT_INITCFG(1)
    2011-01-01 00:04:10 [Informational] kernel: RACFG_CMD_BOOT_UPLOAD(0)
    2011-01-01 00:04:10 [Informational] kernel: RACFG_CMD_BOOT_UPLOAD(1)
    2011-01-01 00:04:10 [Informational] kernel: RACFG_CMD_BOOT_UPLOAD(2)
    2011-01-01 00:04:10 [Informational] kernel: CRC:01 08 14 18 58 45 b1 4f 22 32 2e 35 2e 33 2e 34 22 00 00 00 32 30 31 32 30 34 31 30 00 00 00 00 00 00 00 00 24 8e 00 00
    2011-01-01 00:04:10 [Informational] kernel: RACFG_CMD_BOOT_STARTUP
    2011-01-01 00:04:10 [Informational] kernel: RACFG_CMD_BOOT_NOTIFY
    2011-01-01 00:04:10 [Informational] kernel: Open file: /etc/Wireless/RT6856/iNIC_ap.bin
    2011-01-01 00:04:10 [Informational] Samba Server: daemon is started
    2011-01-01 00:04:12 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:04:13 [Error] smbd[4451]: [2011/01/01 00:04:13, 0] auth/auth_util.c:get_root_nt_token(501)
    2011-01-01 00:04:13 [Error] smbd[4451]: get_root_nt_token: getpwnam”root”) failed!
    2011-01-01 00:04:13 [Error] smbd[4451]: [2011/01/01 00:04:13, 0] services/services_db.c:svcctl_init_keys(420)
    2011-01-01 00:04:13 [Error] smbd[4451]: svcctl_init_keys: key lookup failed! (WERR_ACCESS_DENIED)
    2011-01-01 00:04:15 [Informational] kernel: [smuxctl rem nas8_X]
    2011-01-01 00:04:24 [Informational] kernel: nas8: starting interface.
    2011-01-01 00:04:25 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:04:25 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:04:25 [Informational] WEB: Configuration changed: Wan_PVC
    2011-01-01 00:04:25 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:04:25 [Informational] kernel: launch upnp
    2011-01-01 00:04:25 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:04:25 [Informational] kernel: stop upnp first
    2011-01-01 00:04:25 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:04:25 [Informational] WEB: Configuration changed: Upnpd_Entry
    2011-01-01 00:04:25 [Informational] WEB: Configuration changed: LanguageSwitch_Entry
    2011-01-01 00:04:27 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:04:28 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:04:56 [Error] nmbd[4441]: [2011/01/01 00:04:56, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(396)
    2011-01-01 00:04:56 [Error] nmbd[4441]: *****
    2011-01-01 00:04:56 [Error] nmbd[4441]: Samba name server DSL-N66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
    2011-01-01 00:05:43 [Informational] WEB: User [admin] logged in from [192.168.1.2] via WEB
    2011-01-01 00:08:07 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:08:09 [Informational] kernel: [smuxctl rem nas8_X]
    2011-01-01 00:08:11 [Informational] kernel: nas8: starting interface.
    2011-01-01 00:08:15 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:08:15 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:08:15 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:08:15 [Informational] kernel: launch upnp
    2011-01-01 00:08:15 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:08:15 [Informational] kernel: stop upnp first
    2011-01-01 00:08:16 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:08:16 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:08:22 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:08:22 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:08:45 [Informational] WEB: User [admin] logged in from [192.168.1.2] via WEB
    2011-01-01 00:09:57 [Informational] kernel: check_log_path: [AccessLog]
    2011-01-01 00:01:15 [Informational] syslogd started: BusyBox v1.00 (2018.11.12-18:25+0000)
    2011-01-01 00:01:16 [Informational] WAN Connection: Wan link down.
    2011-01-01 00:01:18 [Informational] stop_nat_rules: apply the redirect_rules!
    2011-01-01 00:01:18 [Informational] kernel: Firmware version=[v9.1.2.3]
    2011-01-01 00:01:20 [Informational] kernel: usbcore: registered new interface driver usbfs
    2011-01-01 00:01:20 [Informational] kernel: usbcore: registered new interface driver hub
    2011-01-01 00:01:20 [Informational] kernel: usbcore: registered new device driver usb
    2011-01-01 00:01:20 [Notice] kernel: SCSI subsystem initialized
    2011-01-01 00:01:21 [Informational] kernel: Initializing USB Mass Storage driver…
    2011-01-01 00:01:21 [Informational] kernel: usbcore: registered new interface driver usb-storage
    2011-01-01 00:01:21 [Informational] kernel: USB Mass Storage support registered.
    2011-01-01 00:01:22 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:01:22 [Notice] kernel: ufsd:: trace mask set to 0000000f
    2011-01-01 00:01:22 [Notice] kernel: ufsd: driver (UFSD_HEAD lke_8.9.0_r209178_b9, LBD=ON, acl, ioctl, sd, wb, tr) loaded at c0302000
    2011-01-01 00:01:22 [Informational] kernel: NTFS support included
    2011-01-01 00:01:22 [Informational] kernel: Big endian platform
    2011-01-01 00:01:22 [Informational] kernel: optimized: speed
    2011-01-01 00:01:22 [Informational] kernel: Build_for__ASUS_PRODUCTS_001_k2.6.22.15_2012-12-24_lke_8.9.0_r209178_b9
    2011-01-01 00:01:23 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:01:23 [Informational] kernel: PCI: Enabling device 0000:02:03.3 (0000 -> 0002)
    2011-01-01 00:01:23 [Informational] kernel: ehci_hcd 0000:02:03.3: EHCI Host Controller
    2011-01-01 00:01:23 [Informational] kernel: ehci_hcd 0000:02:03.3: new USB bus registered, assigned bus number 1
    2011-01-01 00:01:23 [Informational] kernel: ehci_hcd 0000:02:03.3: irq 21, io mem 0x1fba1000
    2011-01-01 00:01:23 [Informational] kernel: ehci_hcd 0000:02:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
    2011-01-01 00:01:23 [Informational] kernel: usb usb1: configuration #1 chosen from 1 choice
    2011-01-01 00:01:23 [Informational] kernel: hub 1-0:1.0: USB hub found
    2011-01-01 00:01:23 [Informational] kernel: hub 1-0:1.0: 2 ports detected
    2011-01-01 00:01:24 [Debug] kernel: ohci_hcd: 2006 August 04 USB 1.1 ‘Open’ Host Controller (OHCI) Driver
    2011-01-01 00:01:24 [Informational] kernel: PCI: Enabling device 0000:02:03.0 (0000 -> 0002)
    2011-01-01 00:01:24 [Debug] kernel: PCI: Setting latency timer of device 0000:02:03.0 to 64
    2011-01-01 00:01:24 [Informational] kernel: ohci_hcd 0000:02:03.0: OHCI Host Controller
    2011-01-01 00:01:24 [Informational] kernel: ohci_hcd 0000:02:03.0: new USB bus registered, assigned bus number 2
    2011-01-01 00:01:24 [Informational] kernel: ohci_hcd 0000:02:03.0: irq 24, io mem 0x1fba0000
    2011-01-01 00:01:24 [Informational] kernel: usb usb2: configuration #1 chosen from 1 choice
    2011-01-01 00:01:24 [Informational] kernel: hub 2-0:1.0: USB hub found
    2011-01-01 00:01:24 [Informational] kernel: hub 2-0:1.0: 2 ports detected
    2011-01-01 00:01:24 [Informational] kernel: usbcore: registered new interface driver usblp
    2011-01-01 00:01:24 [Informational] kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
    2011-01-01 00:01:25 [Informational] kernel: usbcore: registered new interface driver asix
    2011-01-01 00:01:26 [Informational] kernel: usbcore: registered new interface driver cdc_ether
    2011-01-01 00:01:26 [Informational] kernel: usbcore: registered new interface driver rndis_host
    2011-01-01 00:01:26 [Informational] kernel: cdc_ncm: 14-Mar-2012
    2011-01-01 00:01:26 [Informational] kernel: usbcore: registered new interface driver cdc_ncm
    2011-01-01 00:01:27 [Informational] kernel: usbcore: registered new interface driver cdc_wdm
    2011-01-01 00:01:27 [Informational] kernel: cdc_mbim: loaded
    2011-01-01 00:01:27 [Informational] kernel: usbcore: registered new interface driver cdc_mbim
    2011-01-01 00:01:27 [Informational] rstats[3131]: [start rstats]
    2011-01-01 00:03:20 [Informational] WEB: User [admin] logged in from [192.168.1.2] via WEB
    2011-01-01 00:06:50 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:06:50 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:06:50 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:06:50 [Informational] kernel: launch upnp
    2011-01-01 00:06:50 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:06:50 [Informational] kernel: stop upnp first
    2011-01-01 00:06:51 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:06:51 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:07:31 [Informational] WEB: User [admin] logged in from [192.168.1.2] via WEB
    2011-01-01 00:09:41 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:09:41 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:09:41 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:09:41 [Informational] kernel: launch upnp
    2011-01-01 00:09:41 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:09:41 [Informational] kernel: stop upnp first
    2011-01-01 00:09:42 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:09:42 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:09:42 [Informational] kernel: log cicmd 0 (wan vdsl2 set sra on )
    2011-01-01 00:09:42 [Informational] kernel: US bitswap on,DS bitswap on
    2011-01-01 00:09:42 [Informational] kernel: Set SNRM OFFSET = 0.0 db
    2011-01-01 00:09:42 [Informational] kernel: Set Agc Vref1 = 65535 ; Vref2 = 65535 ; Vref3 = 65535
    2011-01-01 00:09:42 [Informational] kernel: log cicmd 1 (wan vdsl2 set target_snrm 32767 )
    2011-01-01 00:09:44 [Informational] kernel: PROFILE30A_MULTI_MODE
    2011-01-01 00:09:45 [Informational] kernel: log cicmd 2 (wan vdsl set agc 65535 65535 65535 65535 )
    2011-01-01 00:09:46 [Informational] kernel: log cicmd 3 (wan vdsl set upbo 255 )
    2011-01-01 00:09:46 [Informational] kernel: log cicmd 4 (wan vdsl set sync_sym off )
    2011-01-01 00:09:46 [Informational] kernel: G.inp mode
    2011-01-01 00:09:46 [Informational] kernel: ANNEXAIJLM
    2011-01-01 00:09:46 [Informational] WEB: Configuration changed: Adsl_Entry
    2011-01-01 00:10:07 [Informational] kernel: set cicmd 5
    2011-01-01 00:10:07 [Informational] kernel: 1: wan vdsl2 set sra on
    2011-01-01 00:10:07 [Informational] kernel: new sra = on
    2011-01-01 00:10:07 [Informational] kernel: 2: wan vdsl2 set target_snrm 32767
    2011-01-01 00:10:07 [Informational] kernel: new target_snrm = 32767
    2011-01-01 00:10:07 [Informational] kernel: 3: wan vdsl set agc 65535 65535 65535 65535
    2011-01-01 00:10:07 [Informational] kernel: new agc_ref = 65535,65535,65535,65535
    2011-01-01 00:10:07 [Informational] kernel: upbo 255
    2011-01-01 00:10:07 [Informational] kernel: cur upbo =1
    2011-01-01 00:10:07 [Informational] kernel: usage: wan vdsl2 set upbo [on|off]
    2011-01-01 00:10:07 [Informational] kernel: 5: wan vdsl set sync_sym off
    2011-01-01 00:10:07 [Informational] kernel: New sync sym update flag :OFF
    2011-01-01 00:10:57 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:10:57 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:10:57 [Informational] WEB: Configuration changed: Wan_PVC
    2011-01-01 00:11:04 [Debug] kernel: nas8_1: no IPv6 routers present
    2011-01-01 00:11:15 [Informational] WEB: User [admin] logged in from [192.168.1.2] via WEB
    2011-01-01 00:12:50 [Debug] kernel: elan.1: add 33:33:00:00:00:01 mcast address to master interface
    2011-01-01 00:12:50 [Debug] kernel: elan.1: add 01:00:5e:00:00:01 mcast address to master interface
    2011-01-01 00:12:50 [Informational] kernel: elan.1: dev_set_promiscuity(master, 1)
    2011-01-01 00:12:50 [Informational] kernel: device elan.1 entered promiscuous mode
    2011-01-01 00:12:50 [Informational] kernel: br1: port 1(elan.1) entering learning state
    2011-01-01 00:12:52 [Informational] kernel: device nas8_0 entered promiscuous mode
    2011-01-01 00:12:52 [Informational] kernel: br1: port 2(nas8_0) entering learning state
    2011-01-01 00:12:56 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:12:56 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:12:56 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:12:56 [Informational] kernel: launch upnp
    2011-01-01 00:12:56 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:12:56 [Informational] kernel: stop upnp first
    2011-01-01 00:12:57 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:12:57 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:13:03 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:13:07 [Informational] kernel: br1: topology change detected, propagating
    2011-01-01 00:13:07 [Informational] kernel: br1: port 1(elan.1) entering forwarding state
    2011-01-01 00:13:07 [Informational] kernel: br1: port 2(nas8_0) entering forwarding state
    2011-01-01 00:13:55 [Informational] kernel: device nas8_0 left promiscuous mode
    2011-01-01 00:13:55 [Informational] kernel: br1: port 2(nas8_0) entering disabled state
    2011-01-01 00:13:56 [Informational] kernel: elan.1: dev_set_promiscuity(master, -1)
    2011-01-01 00:13:56 [Informational] kernel: device elan.1 left promiscuous mode
    2011-01-01 00:13:56 [Informational] kernel: br1: port 1(elan.1) entering disabled state
    2011-01-01 00:13:56 [Debug] kernel: elan.1: del 01:00:5e:00:00:01 mcast address from vlan interface
    2011-01-01 00:13:56 [Debug] kernel: elan.1: del 01:00:5e:00:00:01 mcast address from master interface
    2011-01-01 00:13:56 [Debug] kernel: elan.1: del 33:33:00:00:00:01 mcast address from vlan interface
    2011-01-01 00:13:56 [Debug] kernel: elan.1: del 33:33:00:00:00:01 mcast address from master interface
    2011-01-01 00:14:04 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:14:04 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:14:04 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:14:04 [Informational] kernel: launch upnp
    2011-01-01 00:14:04 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:14:04 [Informational] kernel: stop upnp first
    2011-01-01 00:14:04 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:14:04 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:14:10 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:00:59 [Informational] syslogd started: BusyBox v1.00 (2018.11.12-18:25+0000)
    2011-01-01 00:01:00 [Informational] WAN Connection: Wan link down.
    2011-01-01 00:01:01 [Warning] syslog: LCP: timeout sending Config-Requests
    2011-01-01 00:01:01 [Notice] syslog: Connection terminated.
    2011-01-01 00:01:01 [Notice] syslog: Modem hangup
    2011-01-01 00:01:01 [Informational] syslog: LCP down.
    2011-01-01 00:01:01 [Debug] kernel: vcc_sock_destruct: wmem leakage (2048 bytes) detected.
    2011-01-01 00:01:02 [Informational] stop_nat_rules: apply the redirect_rules!
    2011-01-01 00:01:03 [Informational] kernel: Firmware version=[v9.1.2.3]
    2011-01-01 00:01:04 [Informational] kernel: usbcore: registered new interface driver usbfs
    2011-01-01 00:01:05 [Informational] kernel: usbcore: registered new interface driver hub
    2011-01-01 00:01:05 [Informational] kernel: usbcore: registered new device driver usb
    2011-01-01 00:01:05 [Notice] kernel: SCSI subsystem initialized
    2011-01-01 00:01:05 [Informational] kernel: Initializing USB Mass Storage driver…
    2011-01-01 00:01:05 [Informational] kernel: usbcore: registered new interface driver usb-storage
    2011-01-01 00:01:05 [Informational] kernel: USB Mass Storage support registered.
    2011-01-01 00:01:05 [Informational] syslog: LCP is allowed to come up.
    2011-01-01 00:01:05 [Informational] syslog: qos.txtp.pcr = qos.rxtp.pcr = 0
    2011-01-01 00:01:05 [Debug] syslog: using channel 2
    2011-01-01 00:01:05 [Informational] syslog: Using interface ppp0
    2011-01-01 00:01:05 [Notice] syslog: Connect: ppp0 <–> 0.38
    2011-01-01 00:01:06 [Notice] kernel: ufsd:: trace mask set to 0000000f
    2011-01-01 00:01:06 [Notice] kernel: ufsd: driver (UFSD_HEAD lke_8.9.0_r209178_b9, LBD=ON, acl, ioctl, sd, wb, tr) loaded at c02f1000
    2011-01-01 00:01:06 [Informational] kernel: NTFS support included
    2011-01-01 00:01:06 [Informational] kernel: Big endian platform
    2011-01-01 00:01:06 [Informational] kernel: optimized: speed
    2011-01-01 00:01:06 [Informational] kernel: Build_for__ASUS_PRODUCTS_001_k2.6.22.15_2012-12-24_lke_8.9.0_r209178_b9
    2011-01-01 00:01:08 [Informational] kernel: PCI: Enabling device 0000:02:03.3 (0000 -> 0002)
    2011-01-01 00:01:08 [Informational] kernel: ehci_hcd 0000:02:03.3: EHCI Host Controller
    2011-01-01 00:01:08 [Informational] kernel: ehci_hcd 0000:02:03.3: new USB bus registered, assigned bus number 1
    2011-01-01 00:01:08 [Informational] kernel: ehci_hcd 0000:02:03.3: irq 21, io mem 0x1fba1000
    2011-01-01 00:01:08 [Informational] kernel: ehci_hcd 0000:02:03.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
    2011-01-01 00:01:08 [Informational] kernel: usb usb1: configuration #1 chosen from 1 choice
    2011-01-01 00:01:08 [Informational] kernel: hub 1-0:1.0: USB hub found
    2011-01-01 00:01:08 [Informational] kernel: hub 1-0:1.0: 2 ports detected
    2011-01-01 00:01:08 [Debug] kernel: ohci_hcd: 2006 August 04 USB 1.1 ‘Open’ Host Controller (OHCI) Driver
    2011-01-01 00:01:08 [Informational] kernel: PCI: Enabling device 0000:02:03.0 (0000 -> 0002)
    2011-01-01 00:01:08 [Debug] kernel: PCI: Setting latency timer of device 0000:02:03.0 to 64
    2011-01-01 00:01:08 [Informational] kernel: ohci_hcd 0000:02:03.0: OHCI Host Controller
    2011-01-01 00:01:08 [Informational] kernel: ohci_hcd 0000:02:03.0: new USB bus registered, assigned bus number 2
    2011-01-01 00:01:08 [Informational] kernel: ohci_hcd 0000:02:03.0: irq 24, io mem 0x1fba0000
    2011-01-01 00:01:08 [Informational] kernel: usb usb2: configuration #1 chosen from 1 choice
    2011-01-01 00:01:08 [Informational] kernel: hub 2-0:1.0: USB hub found
    2011-01-01 00:01:08 [Informational] kernel: hub 2-0:1.0: 2 ports detected
    2011-01-01 00:01:08 [Informational] kernel: usbcore: registered new interface driver usblp
    2011-01-01 00:01:08 [Informational] kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
    2011-01-01 00:01:15 [Informational] rstats[2528]: [start rstats]
    2011-01-01 00:01:16 [Informational] kernel: [boa_sslInit, 24]Generate new key.
    2011-01-01 00:01:20 [Informational] kernel: [boa_sslInit, 35]Enabling SSL security system
    2011-01-01 00:01:21 [Informational] kernel: [boa_sslInit, 84]SSL security system enabled
    2011-01-01 00:01:37 [Warning] syslog: LCP: timeout sending Config-Requests
    2011-01-01 00:01:37 [Notice] syslog: Connection terminated.
    2011-01-01 00:01:37 [Notice] syslog: Modem hangup
    2011-01-01 00:01:37 [Informational] syslog: LCP down.
    2011-01-01 00:01:37 [Debug] kernel: vcc_sock_destruct: wmem leakage (2560 bytes) detected.
    2011-01-01 00:01:40 [Informational] kernel:
    2011-01-01 00:01:42 [Informational] syslog: LCP is allowed to come up.
    2011-01-01 00:01:42 [Informational] syslog: qos.txtp.pcr = qos.rxtp.pcr = 0
    2011-01-01 00:01:42 [Debug] syslog: using channel 3
    2011-01-01 00:01:42 [Informational] syslog: Using interface ppp0
    2011-01-01 00:01:42 [Notice] syslog: Connect: ppp0 <–> 0.38
    2011-01-01 00:01:42 [Informational] kernel: Link State: DSL link up.
    2011-01-01 00:01:43 [Informational] syslog: Terminating on signal 15
    2011-01-01 00:01:43 [Informational] syslog: LCP down.
    2011-01-01 00:01:45 [Debug] kernel: vcc_sock_destruct: wmem leakage (512 bytes) detected.
    2011-01-01 00:01:45 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:01:45 [Informational] kernel: nas8: starting interface.
    2011-01-01 00:01:48 [Informational] WAN Connection: ISP’s DHCP did not function properly.
    2011-01-01 00:01:55 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:01:56 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:13:25 [Informational] WEB: User [admin] logged in from [192.168.1.2] via WEB
    2011-01-01 00:17:19 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:17:21 [Informational] kernel: [smuxctl rem nas8_X]
    2011-01-01 00:17:26 [Informational] kernel: nas8: starting interface.
    2011-01-01 00:17:26 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:17:26 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:17:26 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:17:26 [Informational] kernel: launch upnp
    2011-01-01 00:17:26 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:17:26 [Informational] kernel: stop upnp first
    2011-01-01 00:17:26 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:17:26 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:17:33 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:17:34 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:19:25 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:19:27 [Informational] kernel: [smuxctl rem nas8_X]
    2011-01-01 00:19:28 [Informational] kernel: nas8: starting interface.
    2011-01-01 00:19:32 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:19:32 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:19:32 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:19:32 [Informational] kernel: launch upnp
    2011-01-01 00:19:32 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:19:32 [Informational] kernel: stop upnp first
    2011-01-01 00:19:32 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:19:32 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:19:39 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:19:40 [Debug] kernel: nas8_0: no IPv6 routers present
    2011-01-01 00:20:39 [Informational] kernel: tc3262_ptm_close
    2011-01-01 00:20:40 [Informational] kernel: [smuxctl rem nas8_X]
    2011-01-01 00:20:45 [Informational] kernel: nas8: starting interface.
    2011-01-01 00:20:46 [Informational] kernel: _enable_ewan_vlan_tag:disable
    2011-01-01 00:20:46 [Informational] kernel: enable ewan vlan tag(0)
    2011-01-01 00:20:46 [Informational] kernel: generate miniupnpd.conf
    2011-01-01 00:20:46 [Informational] kernel: launch upnp
    2011-01-01 00:20:46 [Informational] kernel: start_miniupnpd. force(1)
    2011-01-01 00:20:46 [Informational] kernel: stop upnp first
    2011-01-01 00:20:46 [Informational] kernel: /userfs/bin/miniupnpd -P /var/log/upnpd.pid -f /var/tmp/miniupnpd.conf &
    2011-01-01 00:20:46 [Informational] WEB: Configuration changed: Route
    2011-01-01 00:20:52 [Debug] kernel: nas8: no IPv6 routers present
    2011-01-01 00:20:53 [Debug] kernel: nas8_0: no IPv6 routers present
    #1716
    • Replies 8,738
    Does sound like an Authentication or VLAN issue?
    How have you obtained Username and Password for ASUS Router PPP Authentication?
    For clarity, hold down reset button for a least 10 seconds and then release and hopefully set-up will start and you can Select Sky Fibre.
    Try the MAC Clone Option (should not be needed, but worth a try)
    Select Zero (0) as priority (if needed)
    VLAN ID is 101
    Set MTU to 1500
    VDSL2 profile to 17a db
    #1717
    Avatarampthetex
    • Replies 10
    I tried with stock firmware that was posted few links back, but that was also saying link down on the dsl, so I reset router to factory, then flashed it with beta, held reset for about 15 seconds, then went through everything, and it was talking to the line, as I could see the data moving, through the uplink. How do I go about the option 61 string, as I have read it must be in HEX?, etc. I did try to convert it online to hex, and put that in but still the same.
    #1718
    Avatarampthetex
    • Replies 10
    I sniffed the details out using wireshark IIRC.
    #1720
    • Replies 8,738
    Try the other options in my above post, especially the MTU etc?
