. john_doe_uk Said:Thank you. I hope they add DoH support to this device.
Maybe worth sending a feedback form and request ASUS add DoH for the DSL-AC51. ![]()
New ASUS DSL-AC51 Firmware version 1.1.2.3_1002
2024/12/02
– Fixed Security Boa http issue
– Fixed Download Master Cannot Upgrade issue
Seems even though the RT-N66U is EoL, ASUS have kindly released a new Firmware Update.
ASUS RT-N66U Firmware version 3.0.0.4.382_52745
2025/03/26
4. Enhance system access control mechanisms.
Download: https://dlcdnets.asus.com/pub/ASUS/…_N66U_300438252745.zip?model=RT-N66U (VER.B1)
Is it possible to add Wireguard VPN client profiles in a future firmware updates of older devices like DSL-AC56U I have?
BTW, in this model, every time I add new static IP address in LAN > DHCP server and press the add button, the device always apply the new setting and is logging me off. I have to login again for the next static IP address. Can this be changed to apply all changes after completion of adding/removing static IP’s at once and only when the Apply button is pressed?
Thanks!
Welcome, unfortunately the DSL-AC56U is no longer supported by ASUS as its End of Life.
ASUS do now have the DSL-AX82U which is a very versitile Modem/Router that also support RMERLIN (ASUSWRT-Merlin) via a @GNUton fork firmware build and I am using currently.
https://github.com/gnuton/asuswrt-merlin.ng
