› UKTH forums › 📺 White & Brown Goods › DishWashers › Miele Dishwasher Fault Codes List of Typical Fault codes for the Miele dish washers (as a guide) Fault Code Description F01 – ...
- This topic has 0 replies, 1 voice, and was last updated 5 years, 8 months ago by
- February 6, 2021 at 3:24 pm #11860
F01 – Water/heating NTC or leads short-circuited
F02 – Water/heating NTC or leads open-circuited
F11 – Drainage fault
F12 – Water intake fault at start of step
F13 – Water intake fault: Heater pressure switch
F14 – Water intake fault: Heater pressure switch
F15 – Water intake fault: Hot water
F18 – Flow meter stationary state monitor B3/4
F19 – Flow meter B3/4 stiff and not turning freely
F24 – Heater relay contact
F25 – Desired temperature fault
F26 – Boiling protection
F40 – Electronic fault
F42 – Line frequency registration fault
F47 – Mains frequency registration fault
F51 – Heater pressure switch
F52 – Heater pressure switch has reset during heating
F53 – Speed sensor fault
F63 – Slide shutter fault
F67 – Circulation pump speed to slow
F68 – Circulation pump operation after switch off
F69 – Circulation pump blocked
F70 – Float switch fault
F84 – Slide shutter positioning fault
F85 – Slide shutter signal change fault
F86 – Salt container lid contact fault
F87 – Sensor softener fault
F88 – Turbidity sensor fault
F91 – Load size registration inactive
