Windows 11 Upgrade by a Different PC or Laptop Interesting thought, so had a windows 10 laptop die on me the other day which was not windows 11 compatible (hardware) and have plugged in the SSD (PCIe NVMe) drive…
› UKTH forums › 💻 Computers › Windows (OS) › Windows 11 Upgrade by a Different PC or Laptop Interesting thought, so had a windows 10 laptop die on me the other day which was not windows 11 compatible (hardware) and have plugged in the SSD (PCIe NVMe) drive...
Viewing 5 posts - 16 through 20 (of 20 total)
  • #26371
    • Replies 8,724
    On kev2021 said
    Found this article which looks to imply it should be removed as its EOL?
    https://www.dell.com/support/kbdoc/en-uk/000204902/dell-data-vault-control-device-is-not-able-to-be-uninstalled-due-to-blue-screen-during-supportassist-installation-uninstallation-or-upgrade
    So I removed the Dell Data Vault Control Device driver from System devices and have rebooted laptop a couple of times and Dell Data Vault Control Device driver entry has not re-appeared
    Thanks for good guidance
    #26373
    • Replies 1,246
    No problem, glad it worked :)
    Now there is an much easier way to install Win11 on unsupported HW.
    Just open the downloaded iso with Windows, it will create a new DVD-path with drive-letter.
    Open cmd, change to the new drive e.g. “L:” and run “setup.exe /product server”.
    It will install the new Win11 with no differences but without hw-checks.
    You have to do it every year after a new yy-h2 is published, as it will do all updates, but not upgrade to a new Win11 release.
    #42405
    • Replies 8,724
    Nice workaround!  has anyone tried using setupprep.exe /product server from the Sources folder? I’ve heard it works on some of the newer 11 builds. Would be interesting to know if anyone here has had success with it.
    #42406
    Dont know the difference, but setup.exe works well for me.
