› UKTH forums › Broadband Tech & ISP’s › PlusNet › Migration from BT Fibre to Plusnet Fibre broadband Service A PlusNet Fibre Journey Ok, so I was on BT Broadband Service until this morning and now have switched over to PlusNet Fibre and thought it would be good...
- This topic has 22 replies, 3 voices, and was last updated 6 years, 4 months ago by
June 3, 2020 at 7:25 am #7880
Ok, so I was on BT Broadband Service until this morning and now have switched over to PlusNet Fibre and thought it would be good for others to follow this process from a DSL Stats perspective.
My Broadband Service via BT was there Fibre 1 option (43Mb – 50Mb) – capped.
Plusnet Service is there Unlimited Fibre Extra (upto 76Mbps) – uncapped
I am on an Huawei Cab and have previously had G.inp enabled, so will be interesting to see what real stats I finally end up receiving.
(Note: I realise this is not a like for like comparison in terms of synch, but given PlusNet Unlimited Fibre Extra was at a lower price than BT Fibre 1 option, it could be compared in terms of ‘value vs synch rate’, maybe)
Below Stats from BT Connection:
Below Stats from Plusnet Connection after Line changed over:
Early days yet and hopefully G.inp and Download Synch speeds will increase ?
June 4, 2020 at 8:06 am #7889Day 1 stats, no Cab re-synch yet and still G.inp is Off
June 4, 2020 at 1:45 pm #7891As you like stats and pics you can use mine for a better sleep at night.
June 4, 2020 at 3:33 pm #7894[quote quote=7891]As you like stats and pics you can use mine for a better sleep at night.
[/quote]
June 6, 2020 at 6:34 am #7900PlusNet re-synch after 4 days, G.inp is On downstream only and Downstream synch speed has increased by 10Mbps
Fastpath has also retuned to Downstream stream as it had a 8ms delay previously, now gone
June 6, 2020 at 8:02 am #7902June 6, 2020 at 9:11 am #7904[quote quote=7902]At least more than before – goal achieved![/quote]
I hope SNR downstream will reduce from 7dB to 3dB giving me an extra 6 Mbps increase ;-)
June 8, 2020 at 5:51 am #7921Day 6 and another synch with cab, SNR is at 6 dB now which gave me an extra 3Mbps downstream speed increase,hopefully will be reduced further to 3 dB
June 10, 2020 at 6:18 am #7931Day 8 and another re-synch, now receiving an extra 3Mbps increase in download speed, stats general seem the same as day 6 except SNR is now 5dB downstream, hence speed increase.
June 10, 2020 at 9:22 pm #7946June 11, 2020 at 5:53 am #7947[quote quote=7946]If you get 3db profile you will be close to 80Mb/s, lucky you
[/quote]I have all my Toes and Fingers crossed
June 12, 2020 at 6:14 am #7972Day 10 and another synch, SNR is now reduced to 4 dB (downstream0 and speed has increased to 75 Mbps (+3) another 1 dB SNR drop to go I think/hope
June 12, 2020 at 7:16 am #7979June 12, 2020 at 7:40 am #7982[quote quote=7979]Nice ;), that will be spot on 80Mb at 3db.[/quote]
June 14, 2020 at 6:57 am #8020Day 12 and another synch, alas no real change this time.
Downstream INP reduced slightly but SNR remained at 4 dB
