Migration from BT Fibre to Plusnet Fibre broadband Service A PlusNet Fibre Journey   Ok, so I was on BT Broadband Service until this morning and now have switched over to PlusNet Fibre and thought it would be good…
› UKTH forums › Broadband Tech & ISP’s › PlusNet › Migration from BT Fibre to Plusnet Fibre broadband Service A PlusNet Fibre Journey   Ok, so I was on BT Broadband Service until this morning and now have switched over to PlusNet Fibre and thought it would be good...
Viewing 8 posts - 16 through 23 (of 23 total)
  • #8075
    Another 4 days have passed and still no change
    SNR remains stubbornly at 4dB (downstream) and now changing modem to DrayTek 130 to see if stats improve
    #8077
    AvatarMrk26
    • Replies 465
    That’s a bit shame, did you have higher amount of errors on 4db profile? I read on different forum that guys capped line to get 3db snr and re-tx low which give you slighty higher throughput compared to re-tx high. Draytek may sync faster but I’m not sure if you will achieve more with it on your Huawei cabinet.
    #8078
    Yes a shame as I thought also I would get to 3 db SNR and achieve nearly 80Mbps, will be interesting what the DrayTeK 130 achieves without tinkering
    Only about 200 FEC over the 14 day period and that was mainly via landline telephone calls etc. my line is usually good.
    #8245
    As a follow up, my I left my Fritz!Box plugged in and another week or so later I have finally reached 3dB downstream which means I am now achieving my 80Mbps synch rate / speed
    G.inp is On for downstream but Off for Upstream, but I do have FastPath On in both directions so gaming will be good and a happier family
    #8248
    AvatarMrk26
    • Replies 465
    For how long you had vigor plugged in?
    Lucky you
    #8252
    In the end, I did not plug vigor in, I left the Fritz!Box plugged in as I was sure it would attain 3dB eventually, and it did ;-)
    Just took a lot longer than I thought it would (25 days) ish
    #8253
    AvatarMrk26
    • Replies 465
    That’s still not bad, 25 days from connection to full speed, some people achieve this result in twice longer period. 😉
    #8254
