MikroTik Releases New RouterOS Stable Build 7.20.6 (Dec 5, 2025) MikroTik Releases New RouterOS Stable Build 7.20.6 Dec 5, 2025 MikroTik has pushed out a fresh RouterOS stable update, version 7.20.6, dated December 5th, 2025. If you’re running RouterOS on…
› UKTH forums › Wireless Routers & Modems › Alternative Router OEMs › MikroTik Releases New RouterOS Stable Build 7.20.6 (Dec 5, 2025) MikroTik Releases New RouterOS Stable Build 7.20.6 Dec 5, 2025 MikroTik has pushed out a fresh RouterOS stable update, version 7.20.6, dated December 5th, 2025. If you’re running RouterOS on...
RELEASE
  • #40430
    • Replies 8,738
    Dec 5, 2025
    MikroTik has pushed out a fresh RouterOS stable update, version 7.20.6, dated December 5th, 2025. If you’re running RouterOS on your router, switch, or wireless device, you’ll want to check this one out.
    What's new in 7.20.6 (2025-Dec-04 14:00):
    *) bgp - fixed missing VRF parameter in template configuration after upgrade;
    *) console - improved service stability and memory allocation when using "regexp" operator;
    *) console - improved service stability when executing commands that can timeout;
    *) dhcp - execute "lease-script" with DHCP server creator user permissions;
    *) pppoe-server - fixed client disconnects when multiple servers with different service names are active (introduced in v7.20);
    *) routerboard - do not show "upgrade-firmware" if available installation is older than minimal supported one;
    *) socksify - listen on all addresses for incoming connections;
    *) system - updated PCI id names;
    https://mikrotik.com/download/changelogs
