› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › Moved: DSL-N16 IPv6 TurkNet Issues [quote quote=20345] Interesting. In UK, we use Dynamic IPv6 (Generally) so IP addresses change over time etc. So you have set up your DSL-N16 using the following page (attachment) for...
- This topic has 29 replies, 4 voices, and was last updated 4 years, 2 months ago by
LazJedi.
- July 29, 2022 at 11:57 am #20347
[quote quote=20345]
Interesting. In UK, we use Dynamic IPv6 (Generally) so IP addresses change over time etc. So you have set up your DSL-N16 using the following page (attachment) for IPv6 ?[/quote]
I always write wrong. XD Defining dynamic IP address. like everywhere.
July 29, 2022 at 11:57 am #20345[quote quote=20343]TurkNet provides static IPv6 addresses to its customers.[/quote]
July 29, 2022 at 1:23 pm #20349[quote quote=20347]I always write wrong. XD Defining dynamic IP address. like everywhere.[/quote]
That makes sense because I just checked with ASUS as they also say for Turknet , IPv6 is Dynamic
July 29, 2022 at 1:28 pm #20350[quote quote=20349]
<noscript>
</noscript>[/quote]So, will Asus produce a solution for these IPv6 incompatibilities?
July 29, 2022 at 2:15 pm #20351Unsure if there is a problem as yet but if there is I am sure ASUS will try there best .
Need to check a few more settings before I ask ASUS to get involved. When you get home tonight can you check …
Q. Does Internet Status: say CONNECTED for Dual Stack ?
If it does say Connected and you have access to Internet, then go to https://www.whatismyip.com/ and see if you have both IPv4 and v6 address
If no access to internet, check logs .
July 29, 2022 at 5:30 pm #20352[quote quote=20351]Unsure if there is a problem as yet but if there is I am sure ASUS will try there best . Need to check a few more settings before I ask ASUS to get involved. When you get home tonight can you check … Q. Does Internet Status: say CONNECTED for Dual Stack ? If it does say Connected and you have access to Internet, then go to https://www.whatismyip.com/ and see if you have both IPv4 and v6 address If no access to internet, check logs .[/quote]
I’m trying now.
July 29, 2022 at 5:51 pm #20354[quote quote=20351]Unsure if there is a problem as yet but if there is I am sure ASUS will try there best . Need to check a few more settings before I ask ASUS to get involved. When you get home tonight can you check … Q. Does Internet Status: say CONNECTED for Dual Stack ? If it does say Connected and you have access to Internet, then go to https://www.whatismyip.com/ and see if you have both IPv4 and v6 address If no access to internet, check logs .[/quote]
It’s very strange, IPv6 addresses were visible on the modem before and not anymore.
July 29, 2022 at 6:14 pm #20358Very Odd, try rebooting router
Was you able to access internet and good to see Internet status as CONNECTED
July 29, 2022 at 6:35 pm #20359[quote quote=20358]Very Odd, try rebooting router Was you able to access internet and good to see Internet status as CONNECTED[/quote]
I’m already rebooting after every setting change. :) I was able to access the internet even when IPv6 addresses were defined, but only with IPv4. Windows network info always says IPv6 no network connection.
July 29, 2022 at 6:46 pm #20361[quote quote=20359]was able to access the internet even when IPv6 addresses were defined[/quote]
Go to https://www.whatismyip.com/ and see if you have both IPv4 and IPv6 addresses
You might find that you need to go to Properties of the wifi/ethernet adaptor (windows) you are using to connect to the router and see if IPv6 is enabled ?
July 29, 2022 at 6:49 pm #20362July 29, 2022 at 7:15 pm #20365July 29, 2022 at 8:11 pm #20366[quote quote=20365]See adapter post above
<noscript>
</noscript>[/quote]Yes, it is enabled by default. :) All the settings you can think of on the computer and modem are as they should be.
July 29, 2022 at 8:27 pm #20367So on PC, if you type ‘IPCONFIG’ does this show IPv4 and IPv6 addresses for Network adapter ?
I will dig out my DSL-N17U tomorrow and test a few options, but it does look like a fault with the firmware for DSL-N16 or a factory reset is required
July 29, 2022 at 8:35 pm #20368 - AuthorPosts
