› UKTH forums › 📡 Broadband Tech & ISP’s › Other Stuff etc. › Moved: Reply To: Hyperoptic Superfast Broadband Any ideas exactly which model router will come with the Hyperoptic service? Is it any good? The service will go live on Tuesday and will have 30 days cooling off.
- This topic has 24 replies, 2 voices, and was last updated 11 months, 3 weeks ago by
dodgydrains.
- January 19, 2020 at 5:15 pm #5822
January 19, 2020 at 6:44 pm #5826Hyperoptic service is US funded (backed) and supplies two types of Router, (I believe)
ZTE H298A and …. (cannot find the other one currently as dinner has just arrived)
January 19, 2020 at 7:38 pm #5827Thanks for that, looks like the other one is Tilgin HG2381. Never heard of either of them
. Enjoy your dinner…..You need to login in order to vote
January 19, 2020 at 8:10 pm #5829Takeway night
The Three models I was thinking where.
- Tilgin HG2381 Hyperhub – Lantiq PXB 4389-720 MHz
- ZTE H298N –
- ZTE H298A
ZTE is Chinese, so basic and Tilgrin is Swedish, so very interesting ?
Let us know how it goes and which Router you end up with ?
January 21, 2020 at 11:12 am #5835I was going to be given the Tilgin HG2381. Unfortunately the lady engineer would not be able to run the cable to my living room. Need to drill a hole through the wall
. Stuck with the DSL AC88U
January 21, 2020 at 12:21 pm #5836What!, was cable going to be run a DSL cable, or did you cancel order ?
January 21, 2020 at 12:31 pm #5837The wiring is already done up to the front door. Once you order they need to drill a hole through the door frame. Then run cat 5 cable to the nearest power outlet.
January 21, 2020 at 12:45 pm #5838I see, Is the wifi on the Tilgin HG2381 poor, which is why you are using the DSL-AC88U ?
Maybe time to get your drill out and finish the job correctly
Edit: forgot to say, if you are stuck with DSL-AC88U using it via WAN port, maybe wise to schedule a weekly reboot of router, a few issues with DHCP they have which a weekly reboot helps with
January 21, 2020 at 1:10 pm #5840I had to cancel the order. There are no wall sockets available in my hallway. They refused to drill a hole to the nearest socket in a room as they only run cabling on the surface indoors.
January 21, 2020 at 1:17 pm #5842I had to cancel the order. There are no wall sockets available in my hallway. They refused to drill a hole as they only run cabling on the surface indoors.
That is really bad luck, but understandable from the Engineers perspective, drilling holes in Internal walls always a chance of hitting a power cable/plastic pipe etc.
Time to get a sparky out to put power socket in hallway, or do it yourself ;-)
January 24, 2020 at 5:59 pm #5862I drilled a hole through the metal door frame in the living room. Hyperoptic came and installed the socket and connected the router (ZTE H298A). Activation is on Monday
January 24, 2020 at 6:05 pm #5863I drilled a hole through the metal door frame in the living room. Hyperoptic came and installed the socket and connected the router (ZTE H298A). Activation is on Monday
Glad u took the plunge and ZTE H298A router, let us know how it goes on Monday ;-)
January 27, 2020 at 7:54 pm #5886Up and running now. Speedtest shows slightly faster than what I ordered. This is over wireless powerline. So far very impressed.
January 27, 2020 at 8:23 pm #5888Lucky chap with those speeds and ping, very impressive ;-)
February 20, 2020 at 11:46 pm #6048I have had Hyperoptic for over 3 weeks now. No complaints so far, blazing fast speed with no slow down or connection issues. Hope it continues this way and I do not have to go back to BT copper lines.
