New R2 firmware – DumaOS-R2-3.0.394.sig New R2 firmware directly from Netduma You can download from the below link: https://www.dropbox.com/s/ctjppykaasmorxp/DumaOS-R2-3.0.394.sig?dl=0 We’d suggest ensuring you factory reset the R2 after making the upgrade as there’s a lot…
› UKTH forums › 🛜 Wireless Routers & Modems › Alternative Router OEMs › New R2 firmware – DumaOS-R2-3.0.394.sig New R2 firmware directly from Netduma You can download from the below link: https://www.dropbox.com/s/ctjppykaasmorxp/DumaOS-R2-3.0.394.sig?dl=0 We’d suggest ensuring you factory reset the R2 after making the upgrade as there’s a lot...
  • #16345
    • Replies 8,694
    We’d suggest ensuring you factory reset the R2 after making the upgrade as there’s a lot of backend changes.
    We’ve now introduced support for WireGuard in Hybrid VPN. If you’re VPN provider offers WireGuard configuration files. For instructions on how to set this up, check out this article.
    http://support.netduma.com/support/solutions/articles/16000127793-how-do-i-use-wireguard-config-files-with-hybrid-vpn-
    Besides this, this firmware is primarily a maintenance update addressing many of the bugs you guys have reported to us since the last firmware update. Check the below change log to see the full details of these.
    Full change log:
    •    Added support for Wireguard in Hybrid VPN
    •    Fixed issue with DHCP service crashing
    •    Added better backend flash usage monitoring for preventing long-term issues
    •    Added improved configuration system allowing for faster and more stable integration of new features
    •    Fixed issue where Wi-Fi password wouldn’t match label after reset
    •    Multiple security improvements
    •    Fixed ‘Rapps not loading’ issue (Big thanks to @pollutionblues for all his help troubleshooting this)
    •    Fixed Hybrid VPN DNS leak issue
    •    System-wide GUI improvements
    •    Added cloud gaming and Work From Home categorisations for QoS
