› UKTH forums › 🛠️ Life & Stuff › Utilities › Octopus Energy Gas and Electricity Smart Meter Installation So this week we had our Gas and Electric meters replaced to the new Smart meter technology that allows us to view via a Smart meter display our real time...
- This topic has 15 replies, 3 voices, and was last updated 4 years, 12 months ago by
November 13, 2021 at 6:12 pm #16202
So this week we had our Gas and Electric meters replaced to the new Smart meter technology that allows us to view via a Smart meter display our real time usage and associated costs.
The engineer replaced both meters in about an hour and so far finding it interesting how much the cost is using heating and cooking etc.
Interesting fact was that both the Gas and Electric Smart meters have an inbuilt (dedicated) battery that is supposed to last upto 10-15 years before replacement is needed.
Also, our Electric meter has a dedicated 3G SIM card (different for up North) that allows in my case Octopus Energy to request a usage report via 3G Â
Communication between Smart Meter and IHD is achieved by the Zigbee protocol.
Gas Meter
Electric Meter
November 13, 2021 at 6:26 pm #16206Replacement Meters Readings:
For those interested in how the new meters will tie in with the old meters from a usage (bill) perspective, the Engineer took a photograph of the old meter readings to send to Octopus and when both the new Smart Gas and Electric meters where installed, they where set to zero (0) which I thought was interesting (I am a bit of a geek sometimes)
November 13, 2021 at 7:07 pm #16208Are you sure its a 3G-SIM card?
Most of EU is shutting down 3G while 2G stays in some countries a bit longer maybe at the longest till end of decade.
Only what I know Czech Rep. made it vice versa and ended 2G while still supporting 3G.
And in Switzerland there is neither 2G nor 3G right now anymore.I cant imagine that you will have 3G next 15 years, they probably bet on the the wrong horse.
November 13, 2021 at 7:32 pm #16210Good point, alas Engineer could have been mistaken but I do know that Gas / Electric and Water etc. is part of the UK’s Critical National Infrastructure (CNI) , so they may have a special arrangement with cell towers and providers etc ?
November 13, 2021 at 8:10 pm #16211Nice, had parents place done couple of years back when they started the SMETS2 smart meters, they have the small SSE meter. They did the same took meter readings, replaced and started from 0.
On your bill, it will likely have old meter number and reading & costs and then the new meter number with the readings and cost.
My place, i only got Elec switched to a smart meter, first SMETS1, then later got changed to SMETS2. Haven’t bothered with my gas as my gas supplier is a small company and they not doing smart meters yet but gas meter box is outside the property so can be read any time easily. Also i seen some SMETS2 gas meters look very small, not the size and depth of your one (which mine is like at the moment). Its one of those small brown triangle type boxes so I’m a little dubious of which type they would replace with. I believe the small ones the battery only lasts 5 years? The gas meter also connects to the Elec meter I believe to send readings back.
November 14, 2021 at 7:39 am #16222Being a cynic – I am sure there are plans that when most of the UK has switched to Smart Meters, there will be an introduction of a two tariffs (much like Economy 7) where for electric they (?) will be trying to encourage the use of power – out of hours (overnight) at a reduced cost, basically to reduce electrical usage requirements / generation during the day .
November 14, 2021 at 6:07 pm #16235November 14, 2021 at 6:56 pm #16238[quote quote=16235]for sure this will happen earlier than you think![/quote]
Does this happen where you are from, different rates for different times of the days for Electricity etc ?
November 14, 2021 at 9:53 pm #16255You can have it if you want to, but bit more monthly costs for dual-meter.
November 15, 2021 at 8:48 am #16267[quote quote=16255]You can have it if you want to, but bit more monthly costs for dual-meter.[/quote]
Are your gas and Electric meters using a data sim cards in Austria, or just certain main cities ?
November 15, 2021 at 5:41 pm #16278Sorry I dont know, I dont even have any smart meter here in Vienna (they are late here and you can op-out), other regions (no difference cities or rural) already changed most electric meters.
What I have found they use GSM/GPRS-SIM.
Gas might be later, no infos about it (I use heat pump) or wether it is planed at all.On last reading they told me water-meter will be changed next year(s) to SIM or whatever can be read from the street nearby.
November 15, 2021 at 6:24 pm #16281November 16, 2021 at 10:00 am #16286Now got more clear infos:
Water-meter will use some NFC-like technique where they can drive through the streets once a year and read out the counters going or driving by.
They have a battery for many years inside. This technology might be used for gas as well I think.Electrical-meters use PLC (dLAN/PowerLAN variant) over the line to send data from one meter to the next to their base station.
But this doesnt work very well and then they send over GSM or NB-IoT, maybe this will be changed to LTE CAT-M in future.You need to login in order to vote
November 16, 2021 at 12:53 pm #16289[quote quote=16286]Water-meter will use some NFC-like technique where they can drive through the streets once a year and read out the counters going or driving by. They have a battery for many years inside. This technology might be used for gas as well I think.[/quote]
This is interesting, I think I will get a job in Austria driving and reading these meters
UK I believe is more simple / basic in that water metered customer will get at least one bill a year based upon a meter readings only.
Where I live we are charged based on occupancy in house and how many showers / bathroom etc. (estimate)
November 16, 2021 at 4:41 pm #16290Better manually read water-meter once a year (every 3 years they will come and between you can do it on your own and mail counter) and get fibre everywhere what is happening in UK.
Here we are far from that!
One of the best mobile coverage and networks worldwide but far behind related to FTTH.
