Renault Kadjar Keyless Card Battery Replacement So our Renault Kadjar Dashboard is telling me that my Keycard battery is low, so I thought I would capture how to change the battery on the Renault Kadjar Keyless…
› UKTH forums › Life & Stuff › Cars › Renault Kadjar Keyless Card Battery Replacement So our Renault Kadjar Dashboard is telling me that my Keycard battery is low, so I thought I would capture how to change the battery on the Renault Kadjar Keyless...
  • #16228
    • Replies 8,739
    So our Renault Kadjar Dashboard is telling me that my Keycard battery is low, so I thought I would capture how to change the battery on the Renault Kadjar Keyless Card for others to follow.
    .’. The Renault Kadjar Keyless Card uses a single CR2032 battery (large circular watch type battery)
    So to gain a access to the battery flip the keycard over so that the Renault logo is upright.
    Then positioning the keycard horizontally, with the two recess (slots) to the Right, gentle push on the white cover right hand end and slide the white cover to the left gentle until the white cover can be removed from the keycards main body.
    Now the battery cover is visible, with a small flat blade screwdriver, gently prize the black battery cover from the top of battery .
    Then insert flat bladed screwdriver under battery as shown and battery should just pop out with a little twist of the screwdriver.
    For re-assemble, just revers the process and test all Keycards functions with car
    #16229
    • Replies 8,739
    Handy Renault Kadjar Keyless Card Battery Replacement video I found on Youtube for those that prefer to watch.
