› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › RT-AX86S Firmware version Hi, Could anyone advise if the latest firmware Version 3.0.0.4.386.46061 is compatible with the RT-AX86S router? it implies it is but when doing a check for update, it says the...
- This topic has 21 replies, 3 voices, and was last updated 4 years, 1 month ago by
kev2021.
May 2, 2022 at 2:43 pm #18874
Could anyone advise if the latest firmware Version 3.0.0.4.386.46061 is compatible with the RT-AX86S router? it implies it is but when doing a check for update, it says the 3.0.0.4.386.45934 is the latest version.
May 2, 2022 at 4:59 pm #18881Why dont you have a look at Asus DL-page?
https://www.asus.com/Networking-IoT-Servers/WiFi-Routers/ASUS-Gaming-Routers/RT-AX86U/HelpDesk_Download/
It clearly says:Firmware
2022/01/11 75.31 MBytes
ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.386.46061
SecurityYou need to login in order to vote
May 2, 2022 at 5:06 pm #18882Hi,
I did but when I clicked the Check button to check for firmware updates on the RT-AX86S it said it was running the latest version, however, it was not 46061, it is running 45934.
I tried to manually update it but it said it failed so I thought maybe it’s failed as it isn’t for the RT-AX86S only the RT-AX86U so thought I’d ask here to see if anyone else has come across this.
May 2, 2022 at 6:12 pm #18883So there might be something wrong with it, either bad download (download again or check checksum) or failure on their side.
May 2, 2022 at 7:32 pm #18885Version 3.0.0.4.386.46061 seems to be suitable for your RT-AX86S and was released ages ago, so if there was any issues – I would have thought they would have sorted it by now.
Most odd
I will make some inquires as it is probable only suitable for RT-AX86U
If manual update fails again, even after you have rebooted router, can you send feedback form with ‘UK Sentinel’ in comments box, so I can get them to chase feedback.
Let me know either way ?
May 2, 2022 at 8:13 pm #18887Sure, will do, thanks
ok, just odd router firmware check says its UpToDate which implies 46061 isn’t compatible/for it..
May 2, 2022 at 9:36 pm #18888Indeed, does sound like an issue ASUS end ;)
May 5, 2022 at 6:57 am #18922As an update. I did speak with ASUS regarding the RT-AX86S and firmware update.
ASUS have suspended Live update for now as they have found some issues, but they believe that firmware Version 3.0.0.4.386.46061 is able to be manually updated (they did a manual trial themselves)
May 5, 2022 at 7:44 pm #18927Hi,
Many thanks, I tried to do it remotely and it failed so I’m waiting till I have some more time to do it when I’m on the local lan and see if it works.
Doing it remotely it failed very soon after starting to upload.
At least this explains why the check firmware says its up to date and not prompt with the latest version :)
I’ll let you know when i can get back to this, likely be end of the month due to work and also looking at some other issues i have atm :)
May 5, 2022 at 7:51 pm #18928
June 19, 2022 at 11:10 am #19265Hi all,
Managed to get the firmware installed, appears it didn’t like doing it remotely so all good.
Noticed no further firmware releases since Jan, has Asus stopped supporting/creating firmware for the rt-ax86U/86S? It is to be replaced by a new router? Last year was a new firmware every couple of months or so.
June 19, 2022 at 12:35 pm #19266Seems the RT-AX86U maybe missing firmware release – Version 3.0.0.4.386.48664, or simular ?
I will prompt ASUS
June 19, 2022 at 3:42 pm #19269Thanks, last one available is Version 3.0.0.4.386.46061 back in Jan.
June 20, 2022 at 7:07 am #19270So ASUS have come back and said next firmware for RT-AX86U/S is Mid July, the firmware has been delayed (I won’t bore you with the details)
Update: now changed as of today, It is good what a prompt can do
June 20, 2022 at 7:53 pm #19275New Firmware today, not under DRIVER and TOOLS, it is under BIOS and FIRMWARE tab
Version 3.0.0.4.386.49447
2022/06/20 76.94 MBytes
ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.386.49447
1. Fixed OpenSSL CVE-2022-0778
2. Fixed CVE-2021-34174
3. Added more security measures to block malware.
4. Fixed Stored XSS vulnerability. Thanks to Milan Kyselica of IstroSec.
5. Fixed CVE-2022-23970, CVE-2022-23971, CVE-2022-23972, CVE-2022-23973, CVE-2022-25595, CVE-2022-25596, CVE-2022-25597
6. Added 3rd party DNS server list in WAN –> DNS to help users enhance the connection security.
7. Supported Safe Browsing in the router app to filter explicit content from search results. You can set it in the router app –> Devices or Family.
8. Improved system stability.https://www.asus.com/Networking-IoT-Servers/WiFi-Routers/ASUS-Gaming-Routers/RT-AX86U/HelpDesk_BIOS/
MD5: b6a82176d1d68547f0aa122d3cc6b843In a completely sane world, madness is the only freedom (J.G.Ballard).
