RT-AX86S Firmware version Hi, Could anyone advise if the latest firmware Version 3.0.0.4.386.46061 is compatible with the RT-AX86S router? it implies it is but when doing a check for update, it says the…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › RT-AX86S Firmware version Hi, Could anyone advise if the latest firmware Version 3.0.0.4.386.46061 is compatible with the RT-AX86S router? it implies it is but when doing a check for update, it says the...
Viewing 7 posts - 16 through 22 (of 22 total)
  • #19276
    • Replies 1,243
    Thanks @UK Sentinel! So is this firmware ok to use or should I give it a while so it can be tested etc as wondering as it been quickly packaged and deployed or gone through usually testing procedures etc lol  Mid July to today is a bit of a leap lol or did they create this one a while back and just forget to release it and therefore will be another one mind July :)
    • Replies 8,707
    I believe somebody go an ear bending back at ASUS HQ
    This build like other ASUS models contains important security updates so I would be tempted to try.
    Edit: other forums are saying latest RT releases for other models are less than ideal, so maybe worth a miss
    #19299
    • Replies 1,243
    Thanks, yes i was having a look online and I see reports of some potential WIFI issues and also debugging still enabled in logs so getting lots of info in logs which I think we had in a earlier firmware but then got turned off/minimised.
    Some people have rolled back due to the issues so I think I’ll leave it for a while and maybe wait for the next release and see what feedback is in, maybe this one was rushed out?
    • Replies 8,707
    Wise choice
    #20274
    • Replies 1,243
    Looks like Asus have a new firmware out:-
    Version 3.0.0.4.386.49599
    2022/07/12 77.11 MBytes
    Anyone tested this as I believe was some issues with the previous one released in June after the long gap from the previous one in Jan.
    • Replies 8,707
    Over at SNB’s – seems release is stable and a mention about Syslogs being more informative
    #20290
    • Replies 1,243
    Thanks, yes the logs seem all over the place, I think after I did one of the updates, I got way more info in logs and since then it’s been more than initial although admittedly I don’t really check them much now as I’ve basically given up getting Sonos to work and everything else is working ok so I’ve just decided to skip Sonos as the units I have are old and Sonos are keen to get you to trade in and pay more for newer versions, wouldn’t mind but they not exactly cheap pieces of kit.
    I’ll give it another couple of weeks until its been out about a month and then I’ll look to update it.
    I’ll check to check out SNB :)
