October 14, 2021 at 6:56 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15801
@UK Sentinel; i will test it tonight and tomorrow.. Thanks for new fw!
October 13, 2021 at 7:28 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15783I’m having the same CRC problem. When I came home today, the number of CRC errors was over 3 million. I didn’t have such a problem before. But I have no problems with internet speed and disconnection.
October 12, 2021 at 7:08 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15775no bro… this is not effected version. Asus Turkiye Customer service sent me this file with email. I wrote them this problem and they sent me this fw…
e-mail scr;
October 11, 2021 at 5:10 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15766Hello. Asus Turkey Customer sent me firmware for this issue. I wonder if the version you published is newer or the one that asus emailed me? link -> https://dosya.oyunsen.com/DSL-AC51_9.1.2.3_945-g470b0ea.trx.zip
note: oyunsen is my site :)
October 9, 2021 at 4:58 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15737October 8, 2021 at 10:00 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15735Hello. I just did the test. In only one of the 4 disconnect attempts, it reconnected in 3.5 minutes. Apart from that, it was instantly connected in all disconnections. I’ve attached the system log below when I had a reconnection problem. It connects faster than previous firmware version. Thank you very much for this -_-
2021-10-09 00:50:20 WEB: Configuration changed: LogAccess_ClearLog
2021-10-09 00:50:40 kernel: The test lab:59
2021-10-09 00:50:40 kernel: new sra = on
2021-10-09 00:50:40 kernel: US bitswap off,DS bitswap off
2021-10-09 00:50:40 kernel: new bs_tx = on
2021-10-09 00:50:40 kernel: new bs = on, autobs = on
2021-10-09 00:50:40 kernel: G.VECTOR on
2021-10-09 00:50:40 kernel: gvt_ns_flag off
2021-10-09 00:50:40 kernel: Set SNRM OFFSET = 0.0 db
2021-10-09 00:50:40 kernel: Set Agc Vref1 = 65535 ; Vref2 = 65535 ; Vref3 = 65535
2021-10-09 00:50:40 kernel: new target_snrm = 3072
2021-10-09 00:50:40 kernel: PROFILE17A_MULTI_MODE
2021-10-09 00:50:40 kernel: new agc_ref = 394,0,0,0
2021-10-09 00:50:40 kernel: cur agc_ref = 394, 0, 0, 0
2021-10-09 00:50:40 kernel: usage: wan vdsl2 set agc_vref [val1] [val2] [val3] [val4]
2021-10-09 00:50:40 kernel: new upbo = 0
2021-10-09 00:50:40 kernel: Showtime sync sym update by pattern on!
2021-10-09 00:50:40 kernel: G.inp mode
2021-10-09 00:50:40 kernel: ANNEXAIJLM
2021-10-09 00:50:40 kernel: G.INP test flag is off
2021-10-09 00:50:40 WEB: Configuration changed: Adsl_Entry
2021-10-09 00:50:43 kernel:
2021-10-09 00:50:43 kernel: PTM reset hold
2021-10-09 00:50:43 kernel: tpstc_txRxReset
2021-10-09 00:50:43 kernel: Link State: DSL link down.
2021-10-09 00:50:49 WAN Connection: Wan link down.
2021-10-09 00:50:50 kernel: [check_FW_version, 6597]Do frs_update.
2021-10-09 00:51:04 WAN Connection: Wan link up.
2021-10-09 00:51:04 syslog: Modem hangup
2021-10-09 00:51:04 kernel: nas8: stoping interface.
2021-10-09 00:51:04 pppoe-relay[2373]: recv (receivePacket): Network is down
2021-10-09 00:51:04 syslog: Connect time 1.0 minutes.
2021-10-09 00:51:04 syslog: Sent 35838 bytes, received 159281 bytes.
2021-10-09 00:51:04 dnsmasq[11711]: reading /etc/resolv.conf
2021-10-09 00:51:04 dnsmasq[11711]: using nameserver 212.154.100.18#53
2021-10-09 00:51:04 dnsmasq[11711]: using nameserver 193.192.98.8#53
2021-10-09 00:51:04 dnsmasq[11711]: ignoring nameserver 127.0.0.1 – local interface
2021-10-09 00:51:04 syslog: Connection terminated.
2021-10-09 00:51:05 syslog: LCP down.
2021-10-09 00:51:09 syslog: Terminating on signal 15
2021-10-09 00:51:09 kernel: [smuxctl rem nas8_X]
2021-10-09 00:51:09 kernel: $s: go into unregister_mulif_device
2021-10-09 00:51:09 kernel: nas8_0: vifname = unregister_mulif_device
2021-10-09 00:51:09 kernel: Release MAC when router interface unregister
2021-10-09 00:51:09 kernel: mulif_release_MacAddress
2021-10-09 00:51:14 WAN Connection: Fail to connect with some issues.
2021-10-09 00:51:25 kernel: Link State: DSL link up.
2021-10-09 00:51:25 kernel: PTM reset release
2021-10-09 00:51:25 kernel: Link State: PVC_8_0 logistic interface down.
2021-10-09 00:51:43 syslog: Timeout waiting for PADO packets
2021-10-09 00:51:43 syslog: Unable to complete PPPoE Discovery
2021-10-09 00:51:43 syslog: LCP down.
2021-10-09 00:51:47 syslog: LCP is allowed to come up.
2021-10-09 00:52:22 syslog: Timeout waiting for PADO packets
2021-10-09 00:52:22 syslog: Unable to complete PPPoE Discovery
2021-10-09 00:52:22 syslog: LCP down.
2021-10-09 00:52:26 syslog: LCP is allowed to come up.
2021-10-09 00:53:01 syslog: Timeout waiting for PADO packets
2021-10-09 00:53:01 syslog: Unable to complete PPPoE Discovery
2021-10-09 00:53:01 syslog: LCP down.
2021-10-09 00:53:05 syslog: LCP is allowed to come up.
2021-10-09 00:53:40 syslog: Timeout waiting for PADO packets
2021-10-09 00:53:40 syslog: Unable to complete PPPoE Discovery
2021-10-09 00:53:40 syslog: LCP down.
2021-10-09 00:53:44 syslog: LCP is allowed to come up.
2021-10-09 00:54:20 syslog: Timeout waiting for PADO packets
2021-10-09 00:54:20 syslog: Unable to complete PPPoE Discovery
2021-10-09 00:54:20 syslog: LCP down.
2021-10-09 00:54:24 syslog: LCP is allowed to come up.
2021-10-09 00:54:24 pppoe-relay[13761]: PADO packet from 00:30:88:1c:e3:8e on interface nas8_0 does not have Relay-Session-Id tag
2021-10-09 00:54:24 pppoe-relay[13761]: PADS packet from 00:30:88:1c:e3:8e on interface nas8_0 does not have Relay-Session-Id tag
2021-10-09 00:54:24 syslog: PPP session is 11959
2021-10-09 00:54:24 syslog: Connected to 00:30:88:1c:e3:8e via interface nas8_0
2021-10-09 00:54:24 syslog: Using interface ppp80
2021-10-09 00:54:24 syslog: Connect: ppp80 <–> nas8_0
2021-10-09 00:54:26 syslog: PAP authentication succeeded
2021-10-09 00:54:26 syslog: peer from calling number 00:30:88:1C:E3:8E authorized
2021-10-09 00:54:26 syslog: local IP address 100.91.53.150
2021-10-09 00:54:26 syslog: remote IP address 172.17.1.135
2021-10-09 00:54:26 syslog: primary DNS address 193.192.98.8
2021-10-09 00:54:26 syslog: secondary DNS address 212.154.100.18
2021-10-09 00:54:26 dnsmasq[11711]: exiting on receipt of SIGTERM
2021-10-09 00:54:26 dnsmasq[20484]: started, version 2.78 cachesize 150
2021-10-09 00:54:26 dnsmasq[20484]: using nameserver 212.154.100.18#53
2021-10-09 00:54:26 dnsmasq[20484]: using nameserver 193.192.98.8#53
2021-10-09 00:54:26 dnsmasq[20484]: reading /etc/resolv.conf
2021-10-09 00:54:26 dnsmasq[20484]: ignoring nameserver 127.0.0.1 – local interface
2021-10-09 00:54:26 dnsmasq[20484]: bad address at /etc/hosts line 2
2021-10-09 00:54:26 dnsmasq[20484]: read /etc/hosts – 5 addresses
2021-10-09 00:54:27 kernel: [route_setting]remove interface[0]=[ppp80]
2021-10-09 00:54:27 kernel: Link State: PVC_8_0 logistic interface up.
2021-10-09 00:54:27 kernel: [qos_execute(9550)]:Force Turn Off Bandwidth Limiter on Guest Network.
2021-10-09 00:54:28 kernel:
2021-10-09 00:54:28 kernel: #### wan_primary: [100.91.53.150]
2021-10-09 00:54:28 kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2021-10-09 00:54:31 WAN Connection: WAN was restored.You need to login in order to vote
October 8, 2021 at 8:17 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15733October 6, 2021 at 5:44 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15698October 6, 2021 at 9:37 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15677October 6, 2021 at 9:37 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15676October 5, 2021 at 9:54 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15668October 4, 2021 at 8:35 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15659won’t come new firmware for older models ! so i will never buy asus products after this time!
October 4, 2021 at 8:10 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15656September 20, 2021 at 6:51 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #154492021-09-20 21:44:47 syslog: Initialize LCP.
2021-09-20 21:44:47 syslog: Plugin libpppoe.so loaded.
2021-09-20 21:44:47 syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
2021-09-20 21:44:47 syslog: pppd 2.4.7 started by admin, uid 0
2021-09-20 21:44:47 syslog: LCP is allowed to come up.
2021-09-20 21:44:54 WAN Connection: Fail to connect with some issues.
2021-09-20 21:45:22 syslog: Timeout waiting for PADO packets
2021-09-20 21:45:22 syslog: Unable to complete PPPoE Discovery
2021-09-20 21:45:22 syslog: LCP down.
2021-09-20 21:45:26 syslog: LCP is allowed to come up.
2021-09-20 21:46:02 syslog: Timeout waiting for PADO packets
2021-09-20 21:46:02 syslog: Unable to complete PPPoE Discovery
2021-09-20 21:46:02 syslog: LCP down.
2021-09-20 21:46:06 syslog: LCP is allowed to come up.log of the reconnection problem.
September 16, 2021 at 7:30 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #15334 -
