September 18, 2022 at 8:26 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20901
[quote quote=20888]When you had lots of CRC’s before, I think you adjusted your CRC to 12 ?[/quote]
I can’t understand what you are saying 🥺
September 15, 2022 at 10:13 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20885September 14, 2022 at 7:56 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20865I reverted from version 979 to version 972. Crc problem in version 979. My version 972 tests started.
September 4, 2022 at 1:48 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20711August 31, 2022 at 3:02 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20664[quote quote=20662]OK, so I have had a response from ASUS. Below log messages are associated with connection logs for WiFi 2.4G and are not error messages. —— 2022-08-17 00:42:03 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5]!! 2022-08-17 00:42:08 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5]!! 2022-08-17 00:42:11 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 3]!! 2022-08-17 00:42:13 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 0) [wcid = 4]!! 2022-08-17 00:42:13 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5]!! 2022-08-17 00:42:16 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 0) [wcid = 3]!! 2022-08-17 00:42:18 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5]!![/quote]
thank you very much
August 26, 2022 at 1:02 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20637[quote quote=20632]
Beta version 979 has some CRC issues. In version 960, it got 30-40 CRC errors per day, but in this version it went up to around 1000-2000.
Interesting, do you notice if the SNR values changed ?[/quote]
The snr setting was off and the value was showing 11.5. I fixed it at 12 this evening and got 7 CRC errors in 6 hours. For now the problem seems to be solved..
August 25, 2022 at 8:03 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20631Beta version 979 has some CRC issues. In version 960, it got 30-40 CRC errors per day, but in this version it went up to around 1000-2000.
August 22, 2022 at 8:11 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20596August 21, 2022 at 11:11 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20581[quote quote=20580]kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5] The logs as highlighted above are used to record state changes in the Wi-Fi Driver I believe, and usually nothing to worry about unless regular disconnects are happening etc.[/quote]
thank you :)
August 20, 2022 at 10:22 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20577why do i take this error ? fw is 960
2022-08-17 00:42:21 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 3]!!
2022-08-17 00:42:23 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5]!!
2022-08-17 00:42:26 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 3]!!
2022-08-17 00:42:27 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 1]!!
2022-08-17 00:42:28 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 0) [wcid = 5]!!
2022-08-17 00:42:31 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 3]!!
2022-08-17 00:42:32 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 1]!!
2022-08-17 00:42:33 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5]!!
2022-08-17 00:42:36 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 3]!!
2022-08-17 00:42:37 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 1]!!
2022-08-17 00:42:38 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5]!!
2022-08-17 00:42:41 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 3]!!
2022-08-17 00:42:42 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 1]!!
2022-08-17 00:42:43 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 0) [wcid = 5]!!
2022-08-17 00:42:46 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 3]!!
2022-08-17 00:42:47 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 0) [wcid = 1]!!
2022-08-17 00:42:48 kernel: PsRetrieveTimeout() Recover ps state(state 3 to state 5) [wcid = 5Attachments:
August 12, 2022 at 10:57 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20549[quote quote=20508]
Hello. I’m having trouble with the time zone and time. I changed the ntp server, but the problem was not solved, the modem remained in 2011 year :) . The error logs are below;
Was this a problem with other / earlier firmware also ?[/quote]
I wasn’t having any problems with older or other versions. But for now, the problem is fixed, if it repeats, I will write again. Thank you
August 8, 2022 at 9:16 am in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20499Hello. I’m having trouble with the time zone and time. I changed the ntp server, but the problem was not solved, the modem remained in 2011 year :) . The error logs are below;
2011-01-01 14:25:06 kernel: clock_sync: TCAPI_COMMIT Timezone
2011-01-01 14:25:12 kernel: clock_sync: TCAPI_COMMIT Timezone
2011-01-01 14:25:18 kernel: clock_sync: TCAPI_COMMIT Timezonehow can i fix this ?
July 26, 2022 at 8:50 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20315July 24, 2022 at 10:20 pm in reply to: Latest Beta Firmwares for DSL-AC51 to DSL-N66U incl. DSL-AC750 Latest DSL ASUSWRT firmware v9.1.2.3_502-g2bdb05b now available. (latest firmware’s are at end of threads) For following ASUS DSL Modem Routers: DSL-AC51 DSL-AC52U DSL-AC55U DSL-AC56U DSL-AC750 DSL-N10-C1 – (extended beta support... #20298 -
