Viewing 15 posts - 541 through 555 (of 1,130 total)
  • #15659
    won’t come new firmware for older models ! so i will never buy asus products after this time!
    #15668
    Who releases beta versions? is Asus ?
    #15669
    [quote quote=15668]Who releases beta versions? is Asus ?[/quote]
    Yes, only beta’s are made and released by ASUS.
    Use the feedback form on you DSL-AC51 and ask them if there are any new beta’s
    Edit: just had an email from ASUS, please see below
    The DSL-AC51 beta firmware with this PADO and PADS packet timeout solution will be provided later
    #15674
    Avatarmorpheus
    • Replies 7
    is that good news?
    #15676
    i think it looks like that..
    #15677
    After this news, I decided to love Asus again.
    #15679
    [quote quote=15677]After this news, I decided to love Asus again. [/quote]
    Love-Hate relationship  then ;-)
    #15698
    Asus completely decides this :)) love? hate?  nowly love
    #15723
    [quote quote=15698]Asus completely decides this :)) love? hate? nowly love [/quote]
    ASUS have kindly produced a beta firmware for the DSL-AC51 that will hopefully address the PADO and PADS packet timeout concern .
    Please test and see if this works better – I have made the download only available for members at it is a test beta firmware.
    [download id="15720"]
    #15733
    i will test it tonight and i will write you. Thanks
    #15734
    [quote quote=15733]i will test it tonight and i will write you. Thanks [/quote]
    #15735
    Hello. I just did the test. In only one of the 4 disconnect attempts, it reconnected in 3.5 minutes. Apart from that, it was instantly connected in all disconnections. I’ve attached the system log below when I had a reconnection problem. It connects faster than previous firmware version. Thank you very much for this -_-
    2021-10-09 00:50:20 WEB: Configuration changed: LogAccess_ClearLog
    2021-10-09 00:50:40 kernel: The test lab:59
    2021-10-09 00:50:40 kernel: new sra = on
    2021-10-09 00:50:40 kernel: US bitswap off,DS bitswap off
    2021-10-09 00:50:40 kernel: new bs_tx = on
    2021-10-09 00:50:40 kernel: new bs = on, autobs = on
    2021-10-09 00:50:40 kernel: G.VECTOR on
    2021-10-09 00:50:40 kernel: gvt_ns_flag off
    2021-10-09 00:50:40 kernel: Set SNRM OFFSET = 0.0 db
    2021-10-09 00:50:40 kernel: Set Agc Vref1 = 65535 ; Vref2 = 65535 ; Vref3 = 65535
    2021-10-09 00:50:40 kernel: new target_snrm = 3072
    2021-10-09 00:50:40 kernel: PROFILE17A_MULTI_MODE
    2021-10-09 00:50:40 kernel: new agc_ref = 394,0,0,0
    2021-10-09 00:50:40 kernel: cur agc_ref = 394, 0, 0, 0
    2021-10-09 00:50:40 kernel: usage: wan vdsl2 set agc_vref [val1] [val2] [val3] [val4]
    2021-10-09 00:50:40 kernel: new upbo = 0
    2021-10-09 00:50:40 kernel: Showtime sync sym update by pattern on!
    2021-10-09 00:50:40 kernel: G.inp mode
    2021-10-09 00:50:40 kernel: ANNEXAIJLM
    2021-10-09 00:50:40 kernel: G.INP test flag is off
    2021-10-09 00:50:40 WEB: Configuration changed: Adsl_Entry
    2021-10-09 00:50:43 kernel:
    2021-10-09 00:50:43 kernel: PTM reset hold
    2021-10-09 00:50:43 kernel: tpstc_txRxReset
    2021-10-09 00:50:43 kernel: Link State: DSL link down.
    2021-10-09 00:50:49 WAN Connection: Wan link down.
    2021-10-09 00:50:50 kernel: [check_FW_version, 6597]Do frs_update.
    2021-10-09 00:51:04 WAN Connection: Wan link up.
    2021-10-09 00:51:04 syslog: Modem hangup
    2021-10-09 00:51:04 kernel: nas8: stoping interface.
    2021-10-09 00:51:04 pppoe-relay[2373]: recv (receivePacket): Network is down
    2021-10-09 00:51:04 syslog: Connect time 1.0 minutes.
    2021-10-09 00:51:04 syslog: Sent 35838 bytes, received 159281 bytes.
    2021-10-09 00:51:04 dnsmasq[11711]: reading /etc/resolv.conf
    2021-10-09 00:51:04 dnsmasq[11711]: using nameserver 212.154.100.18#53
    2021-10-09 00:51:04 dnsmasq[11711]: using nameserver 193.192.98.8#53
    2021-10-09 00:51:04 dnsmasq[11711]: ignoring nameserver 127.0.0.1 – local interface
    2021-10-09 00:51:04 syslog: Connection terminated.
    2021-10-09 00:51:05 syslog: LCP down.
    2021-10-09 00:51:09 syslog: Terminating on signal 15
    2021-10-09 00:51:09 kernel: [smuxctl rem nas8_X]
    2021-10-09 00:51:09 kernel: $s: go into unregister_mulif_device
    2021-10-09 00:51:09 kernel: nas8_0: vifname = unregister_mulif_device
    2021-10-09 00:51:09 kernel: Release MAC when router interface unregister
    2021-10-09 00:51:09 kernel: mulif_release_MacAddress
    2021-10-09 00:51:14 WAN Connection: Fail to connect with some issues.
    2021-10-09 00:51:25 kernel: Link State: DSL link up.
    2021-10-09 00:51:25 kernel: PTM reset release
    2021-10-09 00:51:25 kernel: Link State: PVC_8_0 logistic interface down.
    2021-10-09 00:51:43 syslog: Timeout waiting for PADO packets
    2021-10-09 00:51:43 syslog: Unable to complete PPPoE Discovery
    2021-10-09 00:51:43 syslog: LCP down.
    2021-10-09 00:51:47 syslog: LCP is allowed to come up.
    2021-10-09 00:52:22 syslog: Timeout waiting for PADO packets
    2021-10-09 00:52:22 syslog: Unable to complete PPPoE Discovery
    2021-10-09 00:52:22 syslog: LCP down.
    2021-10-09 00:52:26 syslog: LCP is allowed to come up.
    2021-10-09 00:53:01 syslog: Timeout waiting for PADO packets
    2021-10-09 00:53:01 syslog: Unable to complete PPPoE Discovery
    2021-10-09 00:53:01 syslog: LCP down.
    2021-10-09 00:53:05 syslog: LCP is allowed to come up.
    2021-10-09 00:53:40 syslog: Timeout waiting for PADO packets
    2021-10-09 00:53:40 syslog: Unable to complete PPPoE Discovery
    2021-10-09 00:53:40 syslog: LCP down.
    2021-10-09 00:53:44 syslog: LCP is allowed to come up.
    2021-10-09 00:54:20 syslog: Timeout waiting for PADO packets
    2021-10-09 00:54:20 syslog: Unable to complete PPPoE Discovery
    2021-10-09 00:54:20 syslog: LCP down.
    2021-10-09 00:54:24 syslog: LCP is allowed to come up.
    2021-10-09 00:54:24 pppoe-relay[13761]: PADO packet from 00:30:88:1c:e3:8e on interface nas8_0 does not have Relay-Session-Id tag
    2021-10-09 00:54:24 pppoe-relay[13761]: PADS packet from 00:30:88:1c:e3:8e on interface nas8_0 does not have Relay-Session-Id tag
    2021-10-09 00:54:24 syslog: PPP session is 11959
    2021-10-09 00:54:24 syslog: Connected to 00:30:88:1c:e3:8e via interface nas8_0
    2021-10-09 00:54:24 syslog: Using interface ppp80
    2021-10-09 00:54:24 syslog: Connect: ppp80 <–> nas8_0
    2021-10-09 00:54:26 syslog: PAP authentication succeeded
    2021-10-09 00:54:26 syslog: peer from calling number 00:30:88:1C:E3:8E authorized
    2021-10-09 00:54:26 syslog: local IP address 100.91.53.150
    2021-10-09 00:54:26 syslog: remote IP address 172.17.1.135
    2021-10-09 00:54:26 syslog: primary DNS address 193.192.98.8
    2021-10-09 00:54:26 syslog: secondary DNS address 212.154.100.18
    2021-10-09 00:54:26 dnsmasq[11711]: exiting on receipt of SIGTERM
    2021-10-09 00:54:26 dnsmasq[20484]: started, version 2.78 cachesize 150
    2021-10-09 00:54:26 dnsmasq[20484]: using nameserver 212.154.100.18#53
    2021-10-09 00:54:26 dnsmasq[20484]: using nameserver 193.192.98.8#53
    2021-10-09 00:54:26 dnsmasq[20484]: reading /etc/resolv.conf
    2021-10-09 00:54:26 dnsmasq[20484]: ignoring nameserver 127.0.0.1 – local interface
    2021-10-09 00:54:26 dnsmasq[20484]: bad address at /etc/hosts line 2
    2021-10-09 00:54:26 dnsmasq[20484]: read /etc/hosts – 5 addresses
    2021-10-09 00:54:27 kernel: [route_setting]remove interface[0]=[ppp80]
    2021-10-09 00:54:27 kernel: Link State: PVC_8_0 logistic interface up.
    2021-10-09 00:54:27 kernel: [qos_execute(9550)]:Force Turn Off Bandwidth Limiter on Guest Network.
    2021-10-09 00:54:28 kernel:
    2021-10-09 00:54:28 kernel: #### wan_primary: [100.91.53.150]
    2021-10-09 00:54:28 kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
    2021-10-09 00:54:31 WAN Connection: WAN was restored.
    #15736
    Great news, I will inform ASUS you are happy
    Note: I will ask ASUS to add this improvement to other simular DSL routers also
    #15737
    Give our respect and love to Asus :)
    #15761
    DCWiz
    • Replies 12
    For DSL-AC750 too please… I have some bad CRC that happens some times when the router get the Wan.
    I do not get all of this with the beta tho. Did they moved all the 2016-2018 models out of date?
    Suggest them to make a good new model that will also get updated and will have VOIP phone functionality with the AI-Protection and the other features please.!! And tell em to throw out the window the DDR2’s DDR3’s it’s freaking 2021 finally go create a patent!!
    I do not wanna use crappy outdated DSL\Routers from China why is everyone so jerks in the modem\router job?
