- This topic has 1,129 replies, 77 voices, and was last updated 1 year, 5 months ago by
September 13, 2021 at 11:19 am #15259
@black-bird – that is interesting – is this just modem related or do ASUS RT routers also have the ‘PADO and PADS packet timeout PPPoE connection is timed out’ problem in Turkey ?
Note: This used to an issue also with ASUS RT Routers with the PADO packet timeout problem, but thought that was fixed years ago.
September 13, 2021 at 3:11 pm #15260As you said some years ago there are different dev-teams for RT and DSL, so most likely the patch didnt find its way to DSL or didnt survive more than one or few updates.
Often seen that already fixed problems reoccurred later on.You need to login in order to vote
September 13, 2021 at 4:37 pm #15262@black-bird – that is interesting – is this just modem related or do ASUS RT routers also have the ‘PADO and PADS packet timeout PPPoE connection is timed out’ problem in Turkey ? Note: This used to an issue also with ASUS RT Routers with the PADO packet timeout problem, but thought that was fixed years ago.
I didn’t have an ASUS RT model, so I don’t know about that.
All ASUS DSL models have this problem. That’s why I see people who have to use other DSL devices.You need to login in order to vote
September 13, 2021 at 5:21 pm #15264@black-bird – Understood, I will have a chat with ASUS, could I ask you to send a feedback form on the DSL-AX82U UI regarding this issue and mention UK Sentinel at beginning of description.
Once you have done this Tell me so I can speak with ASUS
September 13, 2021 at 10:11 pm #15265@black-bird – Understood, I will have a chat with ASUS, could I ask you to send a feedback form on the DSL-AX82U UI regarding this issue and mention UK Sentinel at beginning of description. Once you have done this Tell me so I can speak with ASUS
I sent feedback, and this time I took note of it all :)
I hope I’ve been able to explain well enough with the language translation.Feedback content
Feedback with “UK Sentinel”
Asus all DSL modems are struggling with PPPoE connectivity after a DSL outage and a longer PPPoE connection than other modems.
When I look at the system log PADO and PADS packet timeout PPPoE connection is timed out.
if possible, we request an update that fixes this problem for all modems (after a DSL outage to get new IP faster).I don’t know if this may be an ISP problem, but other brand modems don’t have this problem, only Asus brand modems have this problem, I’m sure of it.
I created an DSL outage to send you a sample, and you can see it in the system log.
00:51:23 DSL: Link down -> up
00:55:38 pppd[22743]: Connect: ppp0 <–> wan0
00:55:39 pppd[22743]: PAP authentication succeeded4 minutes passed after DSL connection and received IP
September 14, 2021 at 6:09 am #15268In a completely sane world, madness is the only freedom (J.G.Ballard).
September 16, 2021 at 6:25 pm #15332you are perfect. Thanks !
Half-Life 1 Server IP: hl.oyunsen.com:27015
We will re-write code of world…
September 16, 2021 at 7:22 pm #15333I nearly forgot – ASUS said they will look at both the DSL-AX82U and the DSL-AC52U with regards to the PADO packet timeout problem,
I got the feeling that this is not a priority for them at the moment, but we can all hope
September 16, 2021 at 7:30 pm #15334I hope they produce a solution in dsl51..
September 16, 2021 at 7:44 pm #15335I hope they produce a solution in dsl51..
If ASUS do decide to change anything, it will be for all DSL units except probable the DSL-AC88U, DSL-AC87VG and DSL-AC68VG
September 18, 2021 at 2:05 pm #15426hi, i have the ac55u model, it is getting ip too late and it gives ppoa ppoe vpn verification error what can i do?
September 18, 2021 at 2:20 pm #15427hi, i have the ac55u model, it is getting ip too late and it gives ppoa ppoe vpn verification error what can i do?
What firmware version are you currently using ? and if it is a VPN service you are using, which one is it ?
September 18, 2021 at 2:50 pm #15428September 18, 2021 at 4:01 pm #15429Understood, try the latest version firmware for the DSL-AC55U – Version 1.1.2.3_858
Is this a new modem / router for you that you are trying to set-up?
https://dlcdnets.asus.com/pub/ASUS/wireless/DSL-AC55U/FW_DSL-AC55U_1123858.zip
September 18, 2021 at 4:23 pm #15430 -
