› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Advice needed on what ASUS router (or other) Continuation of discussion from DSL-AX82U thread. Main points below: So my family have somehow been able to get along ok in a 3 story house with something as simple as...
- This topic has 85 replies, 4 voices, and was last updated 3 years, 8 months ago by
January 7, 2023 at 7:43 pm #22338
So my family have somehow been able to get along ok in a 3 story house with something as simple as a Billion 8800NL (in the center of the whole property). Sure it had complete dead spots at the far corners and outside reception was just not a thing but it worked. However, the wireless on it just simply died recently. It would not broadcast an SSID anymore. I managed to get a replacement 8800NL from Ebay for £15 and that was fine. The issue is my brother got some Blink outdoor wireless cameras for the property and as you can guess, it’s having trouble to connect. Now the cameras directly screwed above the doors work good enough (1-2 bar connection) but the one we were thinking of placing approx 10 foot on an adjacent wall to look over the complete driveway is not working well if at all.
It seemed time to look at a new router or better yet, a mesh system to completely cover the house. With only having a 40/10 BT line, it doesn’t really matter the speeds of the satellite nodes. They just have to be able to extend the signal enough to allow the cameras to connect reliably. I have a gaming PC but this will always be wired into the main router. Everything else on the wireless doesn’t need super fast pings or speed.
For years I always thought that ping spikes while downloading or others using internet was just because the CPU on the router sucked. I now know after alot of research recently it’s likely bufferbloat so I thought I may aswell try and solve that problem at the same time (for the wired in gaming PC anyway). I know I needed a router with SQM features (preferably cake or fq_codel).
The options I came up with was Eero, TP-Link Deco and ofcourse ASUS. I also thought to myself that since I’m on FTTC now but FTTP is apparently coming soon, I should get one that will be directly compatible with both. How I saw the products:
Eero: This is such a mixed bag. From all my reading the 2nd gen product seems to be the best because it has cake compared to what I read is a very flawed implementation of fq_codel on the newer 6 models (something about offload engines and very technical stuff). However, as I stated above about PPPoE the 2nd gen eero with cake does not support PPPoE directly. It always has to have a modem infront. The 6 models do support PPPoE directly but then I have an SQM method that barely works and with how expensive it is, not ideal. The thing is I can’t just bridge the 2nd gen as then you lose access to SQM feature…. ahhhhh!!!!!!
TP-Link Deco: This should on paper be a pretty good solution but… something tells me it won’t be. They sell DSL versions of the products (X20-DSL and X73-DSL). The plan there is FTTC directly into the unit and then when FTTP comes, just use one of the 4 ethernet ports on the router (all 4 support PPPoE WAN). The only downside (besides being tied to a smartphone app like Eero) is they have some form of a QoS feature but it’s never going to be anywhere close to cake which is super “plug n play” on Eero. I can’t even find anyone with a Deco product willing to run bufferbloat tests for me to see if their QoS even does anything.
The other thing putting me off TP-Link is privacy issues: https://www.reddit.com/r/hardware/comments/tbthjj/psa_newer_tplink_routers_send_all_your_web/
They said they “fixed” this in firmware updates but none of those DSL units I am looking at had firmware updates.
Asus: The DSL-AX82U seems perfect as a standalone router. It will do the FTTC modem route and serve me well on the move to FTTP. The problem I see myself having is that’s only for one router. I know that all routers have to adhere to transmission power regulations or whatever so I can’t magically think that it will be better than the Billion I have for range (cameras only work on 2.4 Ghz). Since I will need merlin firmware to enable cake, my instincts tell me that I will likely have some issues if I try to add other Asus access points via AiMesh. It’s likely not been tested that much. Plus if I go the multiple Asus router route, it can get somewhat expensive. Even if I go for the non DSL modem equivalent (the TUF-AX5400) that’s still £132. 3 of them and you’re looking at basically £400. With the TP-Link and Eero I can get 3 packs all for under £300 that are unlikely to have as many firmware bugs since it’s official release stuff.
Now I know after reading all this you are likely just gonna say stuff like “just wire access points” but nobody in the house has experience with drilling or laying cables and my family already thinks it’s weird that we now will require 2 devices for internet (gonna use the 8800NL in modem bridge mode for the router/mesh system). Laying cables would just be a no no.
All gaming is basically PC now. Have a PS4 (which is next to the main router anyway) but since I moved to 1440p and high framerate monitor I’m not going back. I play Overwatch 2 mostly and as you can imagine if ping spikes happens then it can be annoying in such fast paced action.
We have 1 iPhone Pro (not sure of model it’s afew years old), 2 Android phones and some tablets (2 iPad and 2 Amazon Fire tablets).
Fortunately the BT master socket is almost directly in the middle so placing the main router in the exact middle is easy. I can’t see the GT-AC5300 in stock at Amazon and tbh I think I should atleast get a Wi fi 6 capable router if it’s only going to be one unit (plus if wifi 6 devices enter later). Do you think the GT-AX6000 is a good choice? I don’t think I can persuade us to fork out £450+ on that one AXE16000 unit but the AX6000 is somewhat reasonable. It’s still alot to fork out if range is still bad but the Eero/TP-Link is always going to be sub £300 for 3 units.
As for FTTP speeds, unless BT ever has an insane deal on I’ll never be going for more than 500 and even that is pretty overkill for our needs. I’ll likely just be on the 150 package as I can get that for £27.99 a month.
If any more info needed let me know.
January 7, 2023 at 8:28 pm #22339Following on from our previous conversations on the DSL-AX82U thread- Wifi 6 based devices are a safe bet, did you get the chance to look at the Netgear XR1000 and its Geo filter etc ?
https://www.netgear.com/uk/home/online-gaming/routers/xr1000/
January 7, 2023 at 9:13 pm #22340I did. It seems pretty useless for my use case in gaming (Overwatch 2). Plus I don’t even know if they support Overwatch 2 but that game only has one dedicated server in EU anyway so I wouldn’t be blocking anything or gaining ping advantage. It also doesn’t seem to have cake support which is either better or atleast equal to whatever implementation they have. I read some 2019 posts that stated they have fq_codel but then some twitter posts in 2020 saying their own algorithms.
January 8, 2023 at 8:21 am #22341Maybe an Overwatch server in UK, maybe minor server and unsure if PC or Console suitable ?
Note: We found this with Fifa, even though when we first started, no UK servers was listed, there is a server just below London that if you selected worked well and have you sub 10ms ping ?
Where as if Geo-filter is disabled, always connected to either France, Germany and even on some occasions the US for fifa games
January 8, 2023 at 10:21 am #22343Thanks for that. In OW and OW2 I was always around 37ms ping. I live in eastern Scotland and every UK streamer I saw (even ones in south England were about 29ms) so it made sense that there was no UK server.
I however don’t want to mess up the competitive server. People saying if you use something like this you have a rsk of getting disconnected from the match when it starts. The game tries to match you against people of equal skill which means people from Germany, Italy and Russia etc. They won’t be connecting to London server.
January 8, 2023 at 12:01 pm #22344No problem and totally understand, so does look like an ASUS RoG type of router that is supported by ASUSWRT-Merlin maybe a good first choice, Wireless 802.11ax and Wifi Mesh capabilities are and added bonus for future consideration, if needed
Off course, there is the DSL-AX82U which is a good all round unit and will also support your needs now and in the future and fully supports Wireless mesh etc. incase you need this also ?
January 8, 2023 at 12:35 pm #22345Yes I think this is a good choice. Are you currently on DSL-AX82U? What does the waveform test score if you enable cake? https://www.waveform.com/tools/bufferbloat
January 8, 2023 at 1:46 pm #22346[quote quote=22345]Yes I think this is a good choice. Are you currently on DSL-AX82U? What does the waveform test score if you enable cake?[/quote]
Alas, DSL-AX82U was unplugged yesterday and does not have @GNUton firmware loaded, only stock firmware.
If I get a chance during the week, I will load @GNUton and plug back in DSL-AX82U and see what results I achieve
Would be interesting to see what your current Billion router results are ?
January 8, 2023 at 2:04 pm #22347https://www.waveform.com/tools/bufferbloat?test-id=2f8858a0-b04c-4108-889f-b1530b3f83ff
B grade. If I do whatever super basic QoS that the Billion is I can just about achieve an A but in no way is it getting to A+
January 8, 2023 at 2:51 pm #22348‘B’ not to bad considering the age of the Billion, will give the DSL-AX82U with @GNUton fork a try this week if I get a chance
January 9, 2023 at 1:51 pm #22365Hi, I myself bought a RT-AX86U and a draytek modem when on FTTC, when i switched to FTTP, I simply removed the Draytek modem and plugged the cable in from the FTTP ONT box which they put inside your house. I then sold the Draytek modem as no longer needed.
When BT installed FTTP, they only test with there router so I plugged in the BT router for testing purposes, then when they left, I removed it and connected to the ASUS router and all was fine.
Might be a option worth considering too rather than buying a DSL router and then buying a non-DSL router?
January 10, 2023 at 8:06 am #22370So flashed my DSL-AX82U with @GNUton firmware release DSL-AX82U_386.08_0-gnuton1 and configured DSL-AX82U to run Cake QoS for testing bufferbloat as per below image (WAN Port not DSL).
Using the waveform tool, tests was mainly ‘A+’ but occasionally did drift towards ‘A’ and I also used DSLReports (my preferred option for this type of testing) and again test results was ‘A+’
Did the test first thing this morning when house was quite and tested by wifi (5GHz) as could not be bothered to disconnect my Xbox as this could wake up family etc.
Hope this helps ?
January 11, 2023 at 9:11 pm #22389Can I ask what the +ms value is on waveform when you don’t get an A+? Under 8ms or so? I know it needs under 5ms to get A+
January 12, 2023 at 7:46 am #22390BUFFERBLOAT GRADE – A
LATENCY
Unloaded – 15 ms
Download Active – +7 ms
Upload Active – +1 ms
January 12, 2023 at 11:51 am #22392How do you figure out stuff like WAN packet overhead value of 27?
